05 C230 Timing Chain Tensioner setting procedure
Old Mar 3, 2013 | 01:35 PM
Dune's Avatar
C230
Guys, I am changing the timing chain tensioner in my 05 C230. I know how to remove and replace, I am looking for guidance on setting the tension properly.
Do I need to soak the tensioner prior to installing?
If anyone can help please do.
Old Mar 3, 2013 | 03:31 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
the chain tensioner is self adjusting ..so just replace everything
Old Mar 3, 2013 | 03:46 PM
Dune's Avatar
C230
Just Curious, what would cause the tensioner to fail? What are signs one has failed?
Glyn M Ruck's Avatar
Super Moderator
See my PM
Ask Hogger. He's just done the job. I've never done it on a M271. I know you screw in the new tensioner still collapsed. It auto releases. Then you hold one cam with a wrench while you apply a 70Nm pull on the crank bolt with a torque wrench with the engine in a specific position & that sets the tensioner. This is from memory. I don't have the WIS procedure for M271 only the 6 cylinder models.
Good luck!
Old Mar 3, 2013 | 03:48 PM
Super Moderator
They don't usually fail. The chain stretches & when you replace it you can't reuse the old tensioner.
