C230 Battery Drain
Old Mar 5, 2013 | 06:15 PM
funnyent's Avatar
c230k
C230 Battery Drain
My C230K dies if it is not started everyday, yet it never shows any error lights for this. I have unplugged both the seat modules, and pulled the fuse for the sunroof controls (both common problems I know of in these cars).
Any other common problems that would cause this? It is intermittant, and the dealer could not figure it out (although they didn't have a problem charging me )
Thanks for your help!
Tim
Old Mar 5, 2013 | 06:18 PM
phister's Avatar
06 C230 SS 6spd
have you tested the battery? how old is the battery? some models have the voltage regulator and sometimes that is a common issue. I dont remember if your year and model has one or not.
Old Mar 5, 2013 | 06:37 PM
funnyent's Avatar
c230k
I replaced the battery about 4 months ago... problem was also occurring before the replacement. Had it tested about a month ago and dealer said that the battery was in great condition. Alternator was also replaced about 2 years ago.
It's strange in that it comes and goes, but makes me nervous each time a turn the key.
Old Mar 5, 2013 | 06:48 PM
phister's Avatar
06 C230 SS 6spd
I would take it to an electrical specialist and see if they can diagnose the issue. they have the right tools to see if something is draining the battery and constantly on even if the car is off.
Old Mar 5, 2013 | 06:51 PM
funnyent's Avatar
c230k
Ok, that's what I will end up doing. Thank you for your help!
Old May 30, 2013 | 10:19 AM
funnyent's Avatar
c230k
Hi All - I finally am home for the summer and took my car into RBM Atlanta to diagnose this problem. They said the drain was coming from my bluetooth tape in my tape player. Anyone ever heard of this? My mom has the same tape in her car (C320) and she has never had any battery drain issues. They said that was the only thing causing it, and for me to just remove the tape.
Is this was the problem at least it was a relatively cheap fix. Any comments?
Old May 30, 2013 | 02:07 PM
PelicanParts.com's Avatar
SPONSOR
Answer
I have encountered this before.
Any after market plug in unit can cause a drain, yours is probably a (common) quality control failure.
If the issue is gone when the bluetooth is removed, you have a solid diagnosis.
whunter@pelicanparts.com
Old May 31, 2013 | 08:55 AM
funnyent's Avatar
c230k
Well Just as I suspected it was not the tape in the tape player. They now said that the rear amp is causing the drain and it will be upwards of $2000 to replace and install. I think I may just drive around without a stereo until I sell it... So far every year since I've owned the car I've dropped 2K on something that wasn't normal maintenance. Ugh
Old Jun 1, 2013 | 01:36 PM
SPONSOR
Ouch
Sorry to hear they misdiagnosed the issue.
I know too many people using a cell phone - ipod, because their OE car stereo will cost more than the car value to repair.
