turn signal in mirror 05 230K Coupe
Old Mar 8, 2013 | 01:46 PM
dougo01's Avatar
2005 230 Kompressor Coupe, 1977 Suzuki PE 250, 1977 Suzuki RM250, 1987 Toyota Supra
Hi Guys I hope you can help me. I get a message in my dash telling me there is a turn signal not working. (mirror passenger side). The turn signal is working fine although sometimes I get the fast click noise for a second before it returns to the normal click noise. I wonder if this is simply a bad connection.
Do I have to remove the mirror? Has anyone else had this problem? Any advice would be appreciated.
Thanks Doug
Old Mar 8, 2013 | 06:33 PM
phister's Avatar
06 C230 SS 6spd
It's a common issue. You can buy some electrical cleaner and spray the harness to clean it up also sometimes the wires get crimped so the harness needs to be replaced or you can get a whole new mirror blinker
Old Mar 10, 2013 | 11:21 AM
dougo01's Avatar
Thanks Phister. This only happens infrequently. I wonder if there is a loose connection at the led lights. Is it difficult to remove the mirror casing? There is a post on removing the mirror but I believe it is for the pre 2005 model year. Any advice would be helpful.
Thanks Doug
Old Mar 10, 2013 | 04:36 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Easily done.
You don't need the special tool this guy makes, but an extra hand helps.
https://mbworld.org/forums/c-class-w...rror-bulb.html
The turn signal come out with the housing and is held in with a couple screws if I recall correctly.
Clean the contacts with a pencil eraser on both sides.
Old Mar 11, 2013 | 10:46 AM
dougo01's Avatar
Thanks for your help. The pdf is fantastic and i'm gonna fix this myself. Going to Myrtle Beach next week and maybe buy the part there if I can save a few bucks.
Old Mar 12, 2013 | 11:38 AM
dougo01's Avatar
Too **** to wait for Myrtle so I made a tool and looked inside the mirror housing. The wiring harness was pinched by the spring. So I freed it up and voila...problem solved.
