License plate light reset
I just received my new LED plate lights. I plugged in to check it out, and nothing. I then plugged the factory back in, nothing (it was working prior to). If I measure voltage on the wires, it fluctuates for 0-12v, and I have an error on the guage cluster. Is there a way I can reset this? Yes, I have research, got nothing. Thanks, Mike.
When you removed the old festoon lamp, you might have damaged it, and it is now open. The LED must be inserted the proper direction with the +12 volts connected to the anode of the LED. Connecting the LED backward will not damage it, but it will not illuminate either. The rear SAM will not work with ordinary LED's because their current is so much lower than the incandescent lamp. Some LED's are made with an internal resistor to allow the same current as the original lamp to flow. This keeps the rear SAM happy. If the resistor is not built into the LED, one can be added externally, but they do get hot so it must be mounted where the heat will not be a problem.
