window pressure sensing
Old Apr 3, 2013 | 06:38 PM
British Bulldog's Avatar
C230 SPORT
Is there any type of window up pressure sensing on the c230 sport to stop children getting fingers trapped
many thanks
british bulldog
Old Apr 3, 2013 | 07:25 PM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
Just tried it with my kids.... No.
Yes there is.
Old Apr 3, 2013 | 10:38 PM
Cintoman's Avatar
2005 C230WZ SS Capri Blue/Ash
Interesting, because my 05 C230SS has it on all four windows as well as my moonroof. In fact, occasionally on the moonroof, it "thinks" it detects something in the way and almost closes then opens partway back again.
Cintoman
Old Apr 4, 2013 | 12:29 AM
phister's Avatar
06 C230 SS 6spd
The sunroof was designed to stop half way if you don't hold down the button to close. If you do the quick press it'll close then open back up.
Old Apr 4, 2013 | 05:04 AM
Moviela's Avatar
many thanks
british bulldog
A module in the door commands the window lift motor. The current passes through a low value resistor when the window is raised or lowered. The voltage across the resistor is the current in the motor. The higher the voltage, the higher the current.
A microprocessor reads the voltage, and if out of range for the firmware it cuts power to the motor. When the window reaches the top, the current goes up and the power is stopped. The module remembers the amount of current and stores that value. When you resync the window after a battery change a new value for current is read and stored.
Old Apr 4, 2013 | 11:10 AM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Great info...much better than a "yes" or "no".
