5 Malfuntions. HELP....
300E
I was driving and suddenly 1 malfunction appeared "Under Voltage Consumer Defective"
after 2 mins, these malfunctions came out:
- Electronic Stabil Prog (Not Available)
- Brake assist (Not available)
- Light sensor
- Battery/Altenator (Visit Workshop)
so with the total of 5 malfunctions plus 2(right and left foglight which I already knew, its because of the HIDs)
I had issues with the battery before, but it didn't shows malfunctions. I brought in my car for 4 times just for the battery issue.
- Light sensor
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
1 Post
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
First, check all fuses and verify their good. It would look bad if you toasted one and the dealer had to charge you for replacing it.
Beyond that:
The voltage regulator is built into the alternator. You should have your dealer replace the assembly as well as the battery.
Beyond that:
