Issues with wiper switch and Driver window switch
Old Apr 11, 2013 | 03:58 PM
Xplay's Avatar
C320
Found this site while trying to find a fix for a few problems I'm having. Figured I'd sign up as this place is very informative.
Anyway, I have two issues with my 2001 C320 that I'm trying to figure out how to fix. First is the wipers, when turning the switch they work on medium and the fastest mode but not on the first mode, the slowest setting. On a RARE occasion it does work on the slowest setting but then once I turn it off and try it again it wont work again. The other speeds work just fine so I'm wondering what could be the problem.
Similar thing happens to the driver window switches. As of now, non of the switches work on the master window switch. My driver window is halfway stuck open as I type this. Also on a rare occasion the main switch would work out of no where, it works when it wants to. Every other window door switch works individually just not on the driver's master switch. Any ideas what could be the problem or if these two issues are related at all considering they both only work when they feel like it. Maybe a short somewhere? I really have no clue so any help or tips would really be appreciated.
Old Apr 11, 2013 | 07:00 PM
Moviela's Avatar
Do the passenger and rear windows work when using the local switches?
It could be the switches in the drivers door are bad, or the driver door module. Have the driver door switches been wet? Spilled liquid or rain? I would suspect even the wires from the switch to the door module might be loose at the connector.
The wiper switch in the stalk might be bad. It is a lot of work to take it out, so you might think about leaving it alone.
In a rare case the two problems could be related. Both items send switch requests on the CANbus which is a serial party-line for the vehicle telematics. If there is a module that is causing the data line to held low nothing can get through. Sounds stupid, but put your wipers on a position that works and try the window. If it works, the wiper switch is hogging the CANbus.
Old Apr 11, 2013 | 07:46 PM
Xplay's Avatar
C320
Thanks for the response, Moviela. As of now, non of the switches work on the driver door master switch but now I went to test the local switches of everything else and I'm getting a problem with the passenger front window now. It only goes down a step with each click. I have to keep clicking the switch on the passenger door for the window to go down or up and it moves little by little to get it open or closed. I don't get it, the rear windows still go up or down like normal. Not sure if anything got wet or not but I guess I should take the panel apart and see if I see any corrosion or loose wires. I turned on the wipers on the working positions too and tested to see if the driver master switch would move any of the windows and it doesn't.
As for the wipers not working on the first slow position, is there a way to test the wiper switch in the stalk? I do plan on taking the dash apart to do the stepper motor noise fix and while I'm at it I can have a look at that.
Old Apr 11, 2013 | 10:44 PM
Xplay's Avatar
C320
Found this thread about the wiper switch.
https://mbworld.org/forums/c-class-w...per-issue.html
Seems like it's the same problem I'm having except I'm only having the problem on the first turn. Anyone else think a new relay might fix this for me since it's just one turn that doesn't work?
Old Apr 12, 2013 | 03:01 PM
samaritrey's Avatar
Super Moderator
THE C350
Does you car have a rain sensor? If you are in the USA all 2001 c320's did so you may want to look and your owners manual to learn how the rain sensor works. If it does not function as it should the sensor or the stalk but I doubt it.
