reprogramming gearbox to engine
Old Apr 21, 2013 | 08:30 AM
EricAnnai's Avatar
w203 2004
can any one help?
i just installed a new engine and a new automatic gearbox in my W203 and after installing the car only drives in the 1st and 2nd gears.the mechanic says i need an expert to reprogramme the gearbox to the engine before the car can have all its speed to the 5th gear.
can i apply the automatic gearbox reset option to solve the problem?
Old Apr 21, 2013 | 10:43 AM
Glyn M Ruck's Avatar
Super Moderator
You need to have the entire ECU/TCU adapted with a Star DAS at the dealer. Then everything will recognise one another & operate normally. At present you are in limp mode.
Old Apr 21, 2013 | 01:32 PM
samaritrey's Avatar
Super Moderator
THE C350
Did you change the size of engine or type of transmission? Did you change out the ECU/TCU from the donor engine?
Old Apr 22, 2013 | 03:30 AM
EricAnnai's Avatar
w203 2004
i changed my engine because the oil pump seized working and resulted in burning bearings and damage to the first piston in the first chamber.
i replaced it with a 3.2L engine but replaced the entire automatic gear box with the same kind.
Old Apr 22, 2013 | 09:09 AM
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
if you are in south Florida u need to see JS Benz.com if you are up north you need to see Rudy and only Rudy at Speedriven.com , both of these can do what the dealer can not do when you install a different eng or tranny into a car like mine removed the 3.2 put in a 5.5 they can reprogram your car. the dealer can not because the vin tells them to set all computers to the old eng or tranny. try the dealler and then when they can't do it then call one of the people i gave you.
Old Apr 22, 2013 | 10:52 AM
Super Moderator
The dealer can do it. They often do for an engine or transmission failure. You need to find a dealer that understands his Star properly & is willing.
Old Apr 22, 2013 | 04:07 PM
EricAnnai's Avatar
w203 2004
thankx for the advice.i have booked an appointment with the dealer on thursday,i will get back to you after our meeting
Old Apr 22, 2013 | 09:02 PM
samaritrey's Avatar
Super Moderator
THE C350
What engine did your car originally have?
Old Apr 23, 2013 | 06:04 AM
EricAnnai's Avatar
w203 2004
it had a 2.6L v6 (m112) engine and replaced with 3.2L v6 (m112)
Old Apr 23, 2013 | 06:14 AM
Super Moderator
C240 to C320 upgrade makes sense & should be easy. Now you just need everything to talk to one another.
Old Apr 27, 2013 | 06:51 PM
EricAnnai's Avatar
w203 2004
after several hours of working on my car the gears only shift from first to second.
what could the prolem be.can any of the sam's be defective?what about the transmission control boad?
Old Apr 27, 2013 | 07:34 PM
Super Moderator
More information please. Several hours of doing what?
Old Apr 27, 2013 | 07:57 PM
EricAnnai's Avatar
w203 2004
if it is TCU,should i change it because i have changed the engine and transmission gear box?
Old Apr 27, 2013 | 07:59 PM
EricAnnai's Avatar
w203 2004
after several atempts to have entire ECU/TCU adapted with a Star DAS the car is still in limp mode
Old Apr 28, 2013 | 03:32 AM
EricAnnai's Avatar
w203 2004
please advice
Old Apr 28, 2013 | 09:11 AM
Super Moderator
It is good practice to keep ECU & engine & TCU & transmission paired. However any TCU for that model gearbox post 2002 should work (pre 2002 TCU's could not be reflashed). You need your old ECU to write across VIN data etc from the EPROM to the new engine's ECU.
Is the Star showing any transmission fault codes that might keep the transmission in limp mode?
The EIS is the top of the control pyramid. Is the EIS recognising the ECU? Can you start the engine?
Is the transmission filled with fluid to the correct level?
Old Apr 28, 2013 | 05:41 PM
EricAnnai's Avatar
w203 2004
my car is 2004 model.for now the ECU has not been changed it is still the one in the car since it was bought.
from what i understand you mean the ECU should be reprogrammed to the new engine and the TCU reprogrammed to the gear box?
there are no fault codes displayed.
yes the EIS recognises the ECU.the car starts well and it is able to move but only in first and second gears.
the transmission has 7L of fluid.
Old Apr 28, 2013 | 06:42 PM
Super Moderator
Yes, if you are using the old ECU it will obviously talk to the vehicle but needs to be remapped for the larger engine fuel rates etc. Are you using your old TCU with a new gearbox? If so it will be talking to the ECU but needs to be adapted to the new gearbox.
If there are no fault codes then this should take the vehicle out of limp mode.
Please make sure that the TCU pilot bush is new & that there are no fluid leaks at the O rings where the TCU harness plugs into the front RH diagonal of the transmission.
Old Apr 28, 2013 | 11:00 PM
amx1397's Avatar
I guess you did not read my post ,,I removed the 3.2 and installed a 5.5 engine, removed the tranny from the 3.2 and installed a tranny from a SL55,, also changed my rear gear ratio from a 307 to 327 all works now. again,, south see JR at JSBenz,,,north see Rudy ar speedriven
Old Apr 29, 2013 | 09:54 AM
Super Moderator
The OP might not live in Florida. OP please complete your profile. Sadly, specialists do sometimes understand the Star DS better than dealers. Some also have developer mode unlocked which can make some things easier.
However, a dealer that knows what they are doing should be able to sort this.
Old Apr 29, 2013 | 06:09 PM
EricAnnai's Avatar
w203 2004
amx1397,I read your post but i do not live in florida.anyway do i also need to change my rear gear ratio?
Glyn, I think there is much logic in your explanation.thankx
Old May 7, 2013 | 09:13 PM
EricAnnai's Avatar
w203 2004
Hi Glyn,
your advice worked for me.my car now drives well n i have all the gears changing smoothly now.thankx
Old May 8, 2013 | 09:41 AM
Super Moderator
Great news! I'm pleased. Thanks for letting us know.
