Not Passing Smog? Here's an Informative Air Pump DIY by Pelican Parts
SPONSOR
Pelican Parts has completed a straight-forward DIY for W203ers showing a step-by-step on how to replace you air pump.
An air pump not operating correctly can cause your W203 car to fail a simple smog test and cause further hassles. Check out the instruction link below which features easy to read steps with pictures!
Click here -> W203 Air Pump Replacement
![](http://im1.shutterfly.com/media/47a3da03b3127ccef2b9c9da94e100000030O00AbOWzlw2ZsWIPbz4W/cC/f%3D0/ls%3D00101368969620130422210615389.JPG/ps%3D50/r%3D0/rx%3D550/ry%3D400/)
Let us know if you need tech assistance anytime!
06 C230 SS 6spd
After doing some research another problem if your secondary air pump CEL comes on is sometimes its the relay in the front sam staying open. Many other owners have switched it to fix the issue but have had issues still with it sticking open. Theres been a trick to attach a ground wire to the ground of the switch and then they ground it to the frame.
