spindle made of what?
Old Apr 25, 2013 | 12:01 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
gunna do the control arms and i was wondering what the spindle is made out of?
i was thinking about just hammering the spindle holding the lca. but dont want to crack anything. (Did this last time)
or should i do the socket method?
thanks
i was draining my coolant when a live BEE came out. Still cant believe it
Old Apr 25, 2013 | 09:58 PM
mleskovar's Avatar
'17 Jaguar XF
thanks
If I'm understanding what you're doing...usually called bushings?...socket method.
Old Apr 25, 2013 | 10:23 PM
Lower control arm
Old Apr 25, 2013 | 11:14 PM
mleskovar's Avatar
'17 Jaguar XF
Lower control arm
If you're talking about disconnecting the ball joint end then you need a special tool. I replaced my bushings in the control arms and didn't disconnect the other end. Your way is much easier but requires a special tool.
Old Apr 26, 2013 | 12:07 AM
if u read my post i already did my lower control arms before using a hammer and a pry bar
a special tool really?
Old Apr 26, 2013 | 12:43 AM
jkowtko's Avatar
2005 c230SS
You are talking about the steering knuckle that the ball joints mount to? I believe those are cast iron or alloy and should be incredibly strong.
I've seen the writeups and videos of both the hammer strike and the socket/wedge method, but I personally used the scissor style separator tool, e.g.:
http://www.ebay.com/itm/Performance-Tech-W83022-Ball-Joint-Separator-/190826959996?pt=Motors_Automotive_Tools&hash=item2c6e2c547c&vxp=mtr
which seems like the most correct way to do this, applying pressure in the most appropriate location and direction. It sounded like a gunshot when the joint finally snapped, but it worked pretty well and required fairly little effort to turn the bolt to pop the joint. (Mostly just cringing and waiting for that loud bang ...)
Old Apr 26, 2013 | 12:48 AM
mleskovar's Avatar
'17 Jaguar XF
Sorry, I didn't know your were asking a rhetorical question. I'm slow.
