amg shock question...
Old Aug 26, 2003 | 06:19 PM
madryan's Avatar
2002 C230k
are the c32 shocks a direct bolt on with the 02 c230 coupe???... is so does anyone have a good set that they want to sell??...
the reason i ask is because i need to change my endlinks (amg sways seemed to have busted them? and i want to change the shocks anyway), and i would rather bolt everything right on
my car has h&r springs and these ny streets with the stiffer bars must have worn out the endlinks.....
another problem is that the endlinks are on backorder.... does anyone know any other sources that sell the endlinks?....
thanks
ryan
Old Aug 26, 2003 | 06:54 PM
Harris's Avatar
The 32 shocks should be a direct bolt on, however, they are not cheap at all. Have you checked on their prices?
Do you have the part number for the end links, I can try in Canada for you.
Old Aug 26, 2003 | 07:12 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the spring rate of the H&R won't be a good match with the AMG shock. It'll shorten the life of the shock dramatically. It's better to get some eibach or bilstein shock that can match with the H&R spring.
