W203 Tech - Belt Tensioner Issues? Parts In Stock Now! by Pelican Parts
Old May 15, 2013 | 01:36 PM
PelicanParts.com's Avatar
SPONSOR
The V-belt tensioner provides a constant tension on the belt which is needed to run all of the engine accessories. Over time the tensioner can fail to maintain the proper tension and the belt will start to slip. If this happens it will usually make a squealing noise. The tensioner can also fail by the bearing wearing out - this will cause the belt to wear unevenly and fray along the edges. You should check your tensioner and V-belt every six months for wear, cracking, fraying, delaminating and drying out. If the tensioner is loose or you can wiggle it or if your belt shows any of these signs you should replace them.
Shop now for replacement belt tensioners for your W203 - Click HERE
Tools required: E10, E12 Torx driver
Applicable Models:
C320 (1998-2004)
E320 (1998-2004)
S320 (1998-2005)
ML320 (1998-2003)
CLK320 (1998-2004)
SLK320 (1998-2003)
If you'd like to see our step-by-step instructions click the link below:
Replacing Your Mercedes Belt Tensioner
You can complete this project in an hour this weekend!
Mark/Pelican Parts
