need an opinion
Old Jul 4, 2013 | 11:04 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
need an opinion
after I sued my former mechanic and won. he gave me more evidence in court against him.
he put on paper that he used 5w-30 liquid moly in my car. which is not approved right?
should I sue him again ill have the same judge? since he potentially damaged my engine I had this oil in my engine in the winter for 7k miles when temps went to 10F.
Old Jul 5, 2013 | 04:27 AM
Moviela's Avatar
Actually Liqui Moly Longtime High Tech 5W-30 from Germany is approved for Sheet 229.5.
I don't know what evidence you could present to prove damage, that is a question for an attorney.
I would think that oil analysis of your current crankcase contents might at least give you peace of mind if your numbers came up in a normal range.
Old Jul 5, 2013 | 09:37 AM
ohhh thanks i couldn't find it on the sheet. i was just gunna sue him again cause he put the wrong oil in. this gives me peace of mind.
thank you thank you ...i should get the transcripts of the case and post it.
Old Jul 7, 2013 | 04:43 PM
samaritrey's Avatar
Super Moderator
THE C350
Curious why you had to sue him in the first place?
Old Jul 7, 2013 | 05:30 PM
I was testing him to see if he was going to rip me off this time and all the other times. mostly maintenance stuff I had him do. i went in for a service b. his website said full inspection and full diagnostic. he has SDS. I knew I need an idle pulley, spark plugs, my e brake sticks, a/c compressor doesn't work, valve cover gakets,, spark plug seals. I get the receipt then it says I need lower ball joints. I went in their with no clunks now the lowers clunk. he was going to give me a refund with a signed contract until he tried to rip it out of my hand. I had evidence backing evidence. I only sued what I had evidence for.
my a/c hasn't worked in like a year now and he said he filled up Freon but who knows.
the a/c vents randomly blow air. I've tried the reset thing and fuses. but I know u can turn the compressor off with a computer
