fernandez86
Do you have a CEL? If so, get them read. If not, go to the dealer and see if there are any codes that they can pull with the STAR scanner. Work from there. It could be the CPU thinking that your foot isn't on the brake, therefore not letting you shift into park or reverse. What you could also do is break the plastic 'stopper' that disallows you to shift gears unless your brake is on. It should be right below the shifter, under the trimmings.
