Transmission shifting but not moving
Old Jul 21, 2013 | 03:09 PM
Sockeyehigh's Avatar
2003 c320 4matic
Got in my car this morning, fired it up. Moved shifter into reverse and nothing. Won't move in any gear. Drove fine yesterday, now it acts as though I'm not moving the shifter. Selector on the dash shows I'm switching from park through the gears, but I get no movement. I can hear what sounds like the linkage moving under the car when I shift. I have tried switching to winter mode and still nothing, not even the slightest movement from the car. 2003 C320 4Matic
Help!!!!
Old Jul 22, 2013 | 04:09 AM
Glyn M Ruck's Avatar
Super Moderator
First thing to check is fluid level.
Check the electrohydraulic bush where the TCU plugs into the transmission on the front RHS diagonal of the tranny for leaks.
Old Jul 22, 2013 | 01:46 PM
2003 c320 4matic
No visible leaks anywhere, can't check level as I don't have the dip stick. It shifted just fine with no issues when I parked it, no previous sign of a pending problem, the shifter feels a bit funny, a little hardto go past neutral into drive....thinking shift cable, but since I am no expert at Mercedes I thought someone else may have had this same issue
Old Jul 24, 2013 | 05:41 AM
Super Moderator
Most unusual but in that case check that the shifting rod has not come adrift.
File Type: pdf
Old Jul 24, 2013 | 09:12 PM
2003 c320 4matic
Ya, damn eclip came off of rod. Thanks for all the help guys!
