No Dead Pedal/Foot Rest?
I'm a little shorter, and I have to cross my left leg to drive comfortably.
Anyone else run into this problem? Is there a foot rest (and mount to bring the rest closer to your foot) that you can buy and install? Any help/suggestions would be great!
If you adjust your seat so that you can press the brake fully without overextending your foot, you should be able to reach the footrest no problem. Did you try to adjust the steering wheel? AFAIK it's telescoping?
And you may want to vacuum the carpet - you are breathing all that
