MAF Clean or Replace?
Old Jul 12, 2013 | 01:36 PM
chazman's Avatar
2006 C230 & 2002 C230
2006 C230 110K Miles getting Check Engine Light for 2 codes, P2188 and P2190.
When I did a search some say cleaning the MAF sensor (aka MAS) fixed it.
Others say, don't waste time cleaning, replace it.
What's your opinion?
(I don't want to ruin the sensor by cleaning it in case that's not the cause of these CEL codes).
Has anyone had a luck with an aftermarket/refurbished one instead of buying from a MB dealer?
Even the aftermarket one is pricey. AutoZone quoted me $270 for a refurbished/aftermarket one and $310 for a new Bosch (OEM?) MAF sensor. I'm MB dealer would sell at even higher price.
Does anyone have any experience and/or advice?
Thanks.
Old Jul 12, 2013 | 02:10 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I replaced mine with a new one from Autohaus AZ for $250; many people have had success with cleaning theirs, but I had no patience for cleaning it, popping it in, seeing if the CEL comes back, recleaning, etc.
I'd rather just do it once and move on.
Old Jul 12, 2013 | 02:18 PM
chazman's Avatar
Did you have the CEL for P2188/2190 or ?
Old Jul 12, 2013 | 02:38 PM
tommy's Avatar
Sorry, spent 10 mins trying to find where I posted the code I was throwing on here, with no luck.
If a good amount of people here are saying that a dirty MAF is the reason for those codes, there's a pretty good chance they are right.
Old Jul 12, 2013 | 03:09 PM
chazman's Avatar
Actually only a few said cleaning did work in this forum (some said reseating the air box to the inlet of the MAF sensor duct fixed - which I already tried with no luck) . In my past experience with MAF sensor (on other brand cars), I didn't have much luck. Cleaning improved the poor running condtion of the car but never took care of the CEL - always came back on. Wonder this might be the case on MB...
Thanks.
Old Jul 12, 2013 | 03:30 PM
tommy's Avatar
Did you clear the codes and see if they came back? That's usually the best first step on a Benz; they have a habit of tripping up once, often for a reason that can't be diagnosed, then never come back on again.
Your logic is what I would use too on the clean/buy decision.
Old Jul 12, 2013 | 04:14 PM
chazman's Avatar
Yes, actually this is exaclty what I have done:
Day 1 - When the CEL came on, I scanned it (too rich) and cleared w/o doing anything. The same CEL code came within 10 miles of driving, and the MPG was still low at 16-18 (used to be 24+ before the CEL).
Day 2- After doing some research, learned that reseating the air box to the MAF inlet duct fixed in some cases. Tried reseating the air box and cleared the CEL, but the same CEL code came back within 10 miles of driving.
Day 3 - After doing some research, learned that cleaning the MAF sensor fixed in some cases. Tried the cleaning and cleared the CEL, but the same CEL code came back on, but after about 30-40 miles of driving now. Also noticed the degraded MPG improved a bit as well, now around 20.
Just called AutoZone and they sell refurbished one for $270 and a new/Bosch for $310.
What brand did you get?
Old Jul 12, 2013 | 06:19 PM
tommy's Avatar
OEM
Old Jul 12, 2013 | 08:36 PM
samaritrey's Avatar
Super Moderator
THE C350
I got a new Bosch one from amazon they had the best price that I could find around $115.
Old Jul 13, 2013 | 10:11 AM
torake's Avatar
C180 Kompressor Wagon
For M112 there are several aftermarket replacement units available, as you already have discovered.
M271 is a different matter alltogether. Different engine management system from different manifacturer (Siemens-VDO vs Bosch)
Old Jul 13, 2013 | 05:08 PM
Moviela's Avatar
Try Bosch (oem supplier) 273-094-09-48 from Pelican Parts, about $150.
You can clean these, but it must be done properly. The sensor is a thermistor pellet in a hermetic glass container. The sensor is heated with a voltage and the volume of air flowing over the thermistor can be measured by changes in the current flowing in the pellet. The change is quite small and a very high impedance amplifier is needed to measure it. The problem is that current can also flow through contamination on the outside of the glass. A finger print will screw the pooch. The CRC MAF cleaner used strictly according to the directions will remove greases, oil, and plain old dirt that interfere with an otherwise working sensor. The chemical dries to the eye pretty fast, but is still present for a little while. I put the unit back in the car and start the engine. The air filter will prevent new contaminates, and the sheer volume of air will dry it in seconds.
Old Jul 15, 2013 | 04:26 PM
chazman's Avatar
So far so good after cleaning - 100+ miles now.
Will see how long this would last.
Old Jul 29, 2013 | 02:12 PM
chazman's Avatar
Just wanted to update you all with my latest result after cleaning the MAF sensor.
The MPG of my 2006 C230 gradually and GREATLY improved over the last 2 weeks (about 3 full tanks of fuel) from the previous disgusting 16 MPG (when I had P2188/P2190 Check Engine Light on).
The driving condition was 90% hwy @60 mph & 10% city with A/C always on when the photo was taken.
I also did following prior to getting the above MPG.
1. New Bosch plugs
2. New air filters
3. Cleaned air intake & fuel system with BG Products shown below.
Old Jul 29, 2013 | 02:23 PM
samaritrey's Avatar
Super Moderator
THE C350
Wow now that's some good mileage is that verified using good ole math? That said I don't doubt it I use to get 32MPG+ with my V6 if I kept the speeds down and traffic was not crazy. I really need to figure out why my car is not doing so well recently going to replace spark plugs this week as well as engine temperature sensor. If neither of those do it I think I may have to replace O2 sensors guess they can become slow after almost 200,000 miles and 12 years.
Old Jul 29, 2013 | 02:50 PM
chazman's Avatar
Not verified yet.
I'm not sure how accurate or inaccurate my C230's built-in dash computer is. But it doesn't really matter for this thread's discussion - because I used to get only miserable 16 MPG according to the dash display!
Old Jul 30, 2013 | 12:05 PM
kluvsbenz's Avatar
2014 E350, 2006 C350 Sport(made it to 280k, loved it!), 1990 300E
1. New Bosch plugs
2. New air filters
Good jobI am glad cleaning did the trick. I would still pick up MAF eventually for a rainy day.
