DIY: Key Battery Replacement
Materials: New battery (CR2025 3v) and small blade.
Here are the directions:
Step 1. Pull the grey lever to the right and pull out the L shaped key.
Step 2.
Step 3. Turn the key to the back side and insert the Key into the left side.
This will press out the back key cover.
Step 4. Take a blade and pull out the battery.
Step 5. Install the new battery and replace the cover. Then reinsert the key.
