Valeo radiator question...
Ive looked at all the threads discussing it and how to identify. its pouring rain right now and looks like it will be for a day or 2 but i went outside and couldnt see much of anything. im doing a flush soon so i guess i can check it out then. but in the bulletin it stated the chassis numbers that were affected. i have an 02 c320 made in 10/2001... so im guessing i have a valeo because they were used until 09/2003? anyway in the bulletin it said the chassis numbers affected and if im correct it has the numbers in your vin.. my vin is WDBRF64J02F201570... so the last six are 201570.. it didnt have that in the list so does that mean im not affected? i figured all pre 03 c classes would be affected with the same radiator.
Who is doing your flush? Are you doing it or someone else? I am pretty passionate about fixing Valeo radiators as I had one in my 2003 C240 and I was also having transmission problems. If I didn't catch it and fix it when I did, I would have had to replace the tranny for around $4,000. I agree, it was a headache to identify, but a Valeo radiator has straight toothed crimping of the radiator end tanks while the Behr has a wavy strip of metal crimping around the end tanks. See the attached link hat shows a Valeo one. http://forums.mercedesclub.org.uk/sh...42&postcount=3 I wouldn't trust it either has on or doesn't have one based upon a VIN check.
Let me ask you, why are you asking? Are you having transmission problems or just being on top of things? If you have a Valeo radiator, you would you would want to replace it and do the flush AFTER they replace it. A flush uses a lot of expensive tranny fluid, so don't do a flush and then find out you have a Valeo radiator and then do another flush.
If you aren't sure, swing past a dealer and ask to see new radiator, and compare to yours.
More informed reading.
https://mbworld.org/forums/2254029-post59.html
thats good to know. i wonder what made mercedes switch to the valeo. or maybe it depends where the car was made. mine is bremen, what about yours? maybe certain factories used them and some didnt...
Yep, my early '03 has the Behr radiator. Quite some time ago I posted some pics when I was trying to figure out which one I had - if I remember correctly one identifying feature was the crimping on the side of the radiator.
Yea I've heard about the crimping on the radiator. I need to get outside and really look at it but from what I saw the other day I'm not sure how ill find out it seems like its hard too see Because of the fan
My understanding is not all Valeos have the leak issue. If I have knew about this issue a few years earlier, I would certainly change it. My w209 (2004) is almost 10 years old and has 270k km, I think my radiator is probably ok.
My indie and I tried to look at my radiator last year but because all the hoses and trims, it was very hard to tell if it was a Valeo or Behr.
Mine went out after 9 years and 120k miles. They aren't all bad, but it I look at replacing it as insurance in case it is a bad one.
