Lights dim when sub bumps hard?
Old Sep 8, 2003 | 01:35 AM
MikeAMG's Avatar
I may have just never had a 1000-watt JL 13w7 in a car before, but when I turn it up hard, each time a deep bass note is hit, the headlights dim on the car...
Is this normal?
Mike
Old Sep 8, 2003 | 01:56 AM
henry47's Avatar
asdf
your subs are eating up the juice. Get a capacitor.
Old Sep 8, 2003 | 02:03 AM
MikeAMG's Avatar
1) what kind would you recommend?
2) is it something i can install myself?
Mike
Old Sep 8, 2003 | 02:15 AM
LorinserCClass's Avatar
The True OG Modded out W203
Go w/whoever installed it. What else are you running? Reason I ask is to find out how many farats you need. W7 13"?!? Hmmm. I got 2 12W6v2 w/a couple of amps and Im running a 10 farat cap and I have no issues w/dimming...just w/other things...
Old Sep 8, 2003 | 02:22 AM
MikeAMG's Avatar
Right now it's just the stock system + 1000-watt J-L amp, and one 13w7 sub. Any idea what kind of cap i need?
Mike
Old Sep 8, 2003 | 02:26 AM
c_klasse's Avatar
c_klasse
i have a 1400 watt amp running a 13 w7 too and i also have a cap my lights don't dimm the they just flicker to the beat of the bass
Old Sep 8, 2003 | 02:30 AM
Yeah you prolly wont need more than a cap or two. In that case get some digi caps! They look SOOO cool
Old Sep 8, 2003 | 02:37 AM
MikeAMG's Avatar
Are we talking about getting one 1 farad cap here?
How do you hook it up?
Mike
Old Sep 8, 2003 | 03:10 AM
kenx818's Avatar
2002 C-240
i have a 1500 watt amp for two 12" Kicker L7 without a problem with the lights
Old Sep 8, 2003 | 03:21 AM
preyx's Avatar
'02 C230K Coupe
You sure you're turning it up high enough??? :p
Anyways, you may want 1 or 2 farad caps installed, depending on how severe the dimming is. And get your audio installer to put the cap in for you; one wrong move during installation and you'll have yourself an electrical fire while you're driving down the street.
Old Sep 8, 2003 | 03:22 AM
MikeAMG's Avatar
Cool, thanks guys
Old Sep 8, 2003 | 06:06 PM
Wide w203's Avatar
in my opinion i think for the best results, you should get 2 caps or run an xtra batt. i had a 1000watt amp b4 in my car running 2 audiobahn dual caps. if you want i am selling the dual caps if you are interested......
i will have about 3,000watts running in my car after it comes out if the system shop..
Old Sep 9, 2003 | 01:48 PM
seandan's Avatar
2002 C230 Coupe
I have a W7 12"
You need to get a extra battery... even with my 10 farad PG cap it still flicks... but when i added my battery everything works fine!
Old Sep 9, 2003 | 04:02 PM
Hey! We have more or less the same setup(kinda). I wanted to get the 20 farat cap but I thought it was overkill!
Old Sep 9, 2003 | 09:31 PM
Rotty's Avatar
05 Navigator
I would recommend an extra battery like seandan said. I run an orion HCCA 15 and my lights flickered, but after the Optima, no more.
