Car Won't Start, Gear Not Detected
Vlad
BTW if it helps I forgot to post the issue that showed on my HUD prior to the problem. Before the issue with the starting arouse, the error that came up was as follows: "Display Malfunction Visit Workshop" an all too familiar dreaded problem as this very issue plagued me back in the Summer of 2011. (Radio change fixed the problem at the time due to Canbus receiving erroneous data from the previous old radio. Samiritrey gladly sold his old one to me and has been working perfectly since, can't thank Sam enough for this, so big about out to him
)But now back on this current issue, the Display Malfunction error has resurfaced again but only briefly. Also the brake wear light came on briefly as well. So I take the key fob out and place it back into the ignition. It recognizes it. So I try to restart it and nothing occurs. No response at all. I move it all the way to the right no cranking occurs, and the gear does not show up on the display. Also all the trip information has dashes on it like the After Start and After Reset information is all blank, i.e; Start Time, Miles Driven, Mpg, So I'm thinking its a computer CANBUS issue once again. I can't shift the gears because upon pressing the brakes it does not send the signal to the shift knob to move it to reverse.
This issue happened to my mom's 2007 G500 and but she was able to start the car. She took it to the dealer, and they fixed it as it was under warranty. This time in my situation the car doesn't start at all after repeated attempts to get it to do so.
At this point the car was towed to the dealer and it is there as we speak. In the interim do you know how easy of a fix this is? Or if it's something simple that I'm overlooking? Help would be greatly appreciated.
Vlad
If not fuses then it sounds like an interlock problem with the shifter. Also check the electrohydraulic bush on the front RH diagonal of the tranny where the ECU plugs in for fluid leaks.
Good luck!
Thanks as always! Wish you had told me this before they towed it lol. Anyway tomorrow they will call me to tell me what's going on. Hope it's a simple fix. Anyway ill keep you all posted.
Vlad
Best
Vlad
You have more wrong than just 52 though.
I just find it hard to believe that the Front SAM Module is the culprit. How could that fail so unexpectedly? I didn't check to see unfortunately if it was Fuse 52 that was blown. As Glyn pointed out. I should've checked that first. And if I find out that they did not check that fuse and it happened to be blown, I will not be paying $1200 dollars. Because thats robbery.
Especially for a 13 year old car. I find it hard to believe that a front computer could go bad. Thats just insanity at best. These stealerships always try to rob people in the best way that they can, replacing parts that are sometimes often unnecessary to replace for no ****ing reason.
I'm really hesistant to pay that much money only to be strapped with another problem again.
Only reason why I had it towed to the dealer was because it was complimentary and free, otherwise I would've had it towed to my house, which was what I should've done.
Vlad, the SAM replacement solved all your issues?
Thanks!
Vlad
