TELEAID BATTERY DRAIN
Upon my initial search of the persistent batt drain, using a multimeter, I found a dramatic drop once I pulled fuse no. 40 (teleaid). Any recommended solutions anyone?
I have yet to test more fuses in the trunk until tomorrow. For now the teleaid showed the drop.
Is it safe to just leave the #40 fuse out for a while?
Thanks for the assist.
Unless you paid a small fortune for a new digital system, you can leave the fuse out forever because no one is listening.
How much did the current change? We all like to know.
It usually drains overnight so I take the neg. battery cable out every time. I will leave it hooked up tonight and see if it will grain with the fuse out.
Thanks.
Thanks.
70 milliamps sound like a normal key out current draw. Perhaps unplug the teleaid module in the trunk to confirm it is the bad actor.
I have a few CenTech meters from Harbor Freight. They are not going to replace my Fluke anytime soon, but they are reasonably accurate. I get them free from coupons in the mail.
The problem now is the malfunction messages. I have 2 of them: The teleaid, of course, and SRS(key in).
Is the SRS going to be a safety issue problem I have to be concerned about?
I know the codes can be erased...but by disconnecting the module solve the error messages?
Battery charge: 12.71 V (car off)
Thx.
It is possible the SRS problem is related to the weight sensor in the passenger seat cushion.
I think this problem would not be fixed for a awhile. Funds are very limited at the moment just hardly working and in college. At least I know what is going on with the car.
I think i'll just keep on pulling the fuse after every use.
This really sucks.
Do you know the cost to remove it an an indie shop?
Thx.
@turbonos: The SRS error appears when I pull the fuse out with the key in the ignition...Don't know why. I'm testing if I put the fuse back in but take the module connection off ,maybe it will get rid of the SRS light. It only happens when the key is in. I only get the teleaid error in key out.
Thanks for the help.
Now the million dollar question: How do you take it out?
Is the whole black part it? Does it pull straight out? I tried and felt like I was pulling enough already but it would not come off. Also tried to pull that metal part out without success.
Just don't want to break anything...looks expensive.
Thanks.
Pic attached.
Thanks.
Pic attached.
Why is the SRS acting up if it not related to teleaid? And teleaid is analog,is it not?
Does this mean the aribag won't be working?
As designed the modules on the canBUS go into a sleep mode when not spoken to for a period of time. Some modules have a history of staying awake (like children) when they should be sleeping. The early seat modules are the worst offenders.
The SRS system can alert TeleAid (when it was live) that an airbag had been deployed. TeleAid would alert the police of your location. The SRS might be complaining that the TeleAid is not listening when you remove the fuse or unplug the Motorola TeleAid module.
I suggest you get a Star DAS service shop to recode the SAM that TeleAid is not present, and the SRS system should settle down. You can then remove the Motorola box.
Is there a switched 12V in there close?
Will a different module fix the problem or is it an electrical problem caused by something else that affected the teleaid?
Anybody Pls reply. I'm planning to buy it as soon as I get some opinion/s. Pulling the fuse out every time is getting annoying. I never used teleaid and I can't afford an upgrade either. Just want to rid of the persistent drain problem and error messages.
Thanks.
SRS? Who's talking about that? He already removed the fuse to the teleaid module anyways so I don't follow....?
