Please Help me C320 2005
Perry
Seriously I've heard this is an intermittent issue for which there is no definite cure. I've had the "left turn signal mirror light" come on periodically for a couple of years now. I ignore it and it goes off again. I'm not sure but I think the warning sensors measure resistance across the light bulb circuit -- so possibly replacing the bulb will help?
I'd just replace the light strip with a new one, and see if the message goes away. It's not that expensive.
I know that people here have said that you can individually replace the bulbs, but I have no idea. When I updated my lights, I did the strips as a whole.
I would give the connector a spritz with contact cleaner. If that fails, I cut a fine grit emery board (from my manscaping kit.) to a narrow point to lightly sand the male pins.
You talking to me Tommy? I was saying that I've seen moisture get into the side mirror blinker area... that's all....
