Are these add-ons and replacement parts compatiable w/ my w203
I have a mercedes benz c240 year 04 and 4 Matic
I realize that ebay has this section that can check if the part is compatiable with my model i use that from time to time and most of the time it's NOT compatiable so i dont want to make the same mistake with these expensive parts.
Part #1
I have to replace the entire turn signal switch is this correct part?
http://www.ebay.com/itm/120900344110...84.m1438.l2649
Part #2
I have to place sensor that displays the message "Reduce Oil Level" is this the correct part?
http://www.ebay.com/itm/261062443566...84.m1438.l2649
Part#3
This is not a part but i would like to change the radio from factory radio to this Pioneer AVH P4400 and i know nothing about car radios so i was wondering if this part is compatiable with my car?
http://www.ebay.com/itm/370872757922...84.m1438.l2649
As for the radio there are many threads on here talking about that but I will give you a little help. First does your car have the Bose stereo? if so changing the radio just got way more expensive and if you don't want a headache just live with your normal one. If not then you need to find a dash kit (make sure the head unit you chose to put in fits) and wiring harnesses ect.
