transmission range sensor for 05 c230k
Have you spilt anything down past the shifter lever? Is there a hole in the leather boot?
Otherwise:
- Faulty Park/Neutral Position Switch
- Misadjusted Park/Neutral Position Switch
- Park/Neutral Position Switch harness is open or shorted
- Park/Neutral Position Switch circuit poor electrical connection
Remove the entire shifter & clean everything otherwise you will have to replace as a unit.
