c320 04 no cranks,loud fan help me
Old Oct 12, 2013 | 11:15 AM
BradyMiklos's Avatar
e320
Hi i have 04 c320 v6
When i try to run no cranks nothings wrong when turn complete key the engine fans starts super fast very fast n loud
Cluster have some error eps abs or srs
My car come with die battery i put a good batery around 100amp of crack
Anyone can help me
Old Oct 12, 2013 | 12:54 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Start searching and reading,.... likely NOT a problem with your front radiator fan. Front radiator fan is designed to default to spin in high mode like turbine engine when it does NOT get signal from ECU (assumes engine is overheating). Have you ever messed with ECU,....
"Coolant Visit Workshop" - Kill Engine Signal - Radiator/Engine Fan in High Mode
https://mbworld.org/forums/c-class-w...high-mode.html
ECU Failure - Rattling ECU (ECM - ME)
https://mbworld.org/forums/c-class-w...cu-ecm-me.html
Seriously doubt ECU failure is from changing battery,... ECU is heavily protected by fuse & breakers in frontSAM.
How did you change car battery? Did you follow owners manual when changing car battery,.... you might have blown your frontSAM. Search for that too,...
Hook up ODB2 scan tool to read codes.
Old Oct 12, 2013 | 04:08 PM
e320
Thanks reply
I will check coolant level
Other question the towing guy i dont what remove of the car moves with parking position P ,if i press brake pedal can move to n,d shifter
I check if the towing remove rear axle or tranny shaft but all parts of differential axles in right position
If dont have key with brake pedal press shifter dont move just with key position 2 o 3
In dash moves to p,r,n,d
