2006 C230 SPUTTER LIKE MOVEMENT?
Old Oct 17, 2013 | 01:49 PM
leonelalbarran's Avatar
2006 C230 Sport
I have a 2006 c230 sport sedan with about 81k miles. The other day I was driving it and when I was coming to a stop I pressed the brakes. Released them a bit and then pressed them again. At this point the car began to do this sputtering motion. It did this for about the next 2 stops and at a complete idle it was a bit rough. It wasn't shaking out of control but it was shaking a bit at a complete stop. I pulled over, turned the car on and off and it completely stopped. Any help will be GREATLY APPRECIATED? I am new to mercedes
Old Oct 18, 2013 | 04:58 PM
Khan28's Avatar
2012 C300 Sport 4MATIC (current) 2006 C280 Elegance 4MATIC (sold)
Not sure exactly what might be wrong but you can start with changing air filters if they're dirty, removing and cleaning the MAF sensor with MAF cleaner and removing the elbow below it and cleaning the throttle body with throttle body cleaner and a shop towel. I recently did that to my C280 and the occasional rough idle is gone and at cold start ups the engine doesn't shake as much for the first 30 seconds like it used to. Spark plugs and fuel filter should be changed at around 105,000 kms so if that hasn't been done yet might as well change those items. Plenty of DIYs here on the forum if you plan on doing this yourself.
Old Oct 18, 2013 | 07:57 PM
jogger's Avatar
02 S500
do you have a check engine light?
Old Oct 19, 2013 | 11:13 PM
2006 C230 Sport
I had it looked at the dealership and they said it registered on the computer that it misfired but it hasnt happened since so I hope that was it!
