maf code won't go away p101
I was given advice it was a maf problem.
3 mafs later, including an original Mercedes, I still have this problem.
I have looked around for some obvious leaks to the inlet manifold, still no luck.
I have seen with the six cylinders on the forum, that they can have vacuum units fail on the inlet manifold.
Is there any common problem with the m111 engine which keeps a maf code reoccurring?
Any help happy to be received.
