Old Jun 16, 2015, 01:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Problems after cleaning Throttle Body
Old Nov 26, 2013 | 06:41 PM
garretts228's Avatar
c240
I am having a few issues after cleaning my throttle body. To start off I have a 2002 C240 with 175,000 miles. The other day I decided to clean out my throttle body, because of a rough and low idle. I removed the MAF, the elbow, and the hoses connecting to it. I cleaned it out the throttle body, lifted back the butterfly to get behind and around the edges of it... I tried to do the best I could with the room I had. Upon removing the hoses, I broke the driver side breather hose because of how dry rotted it was. It idled at about 2,000rpm and my gas mileage was terrible. After making a trip to the dealer to replace the hose $16.05, and putting it on there I started my car, and seemed well. Well, after going around the neighborhood, and coming to a stop I experience a rough downshift. I bring it back to the house and the car is idling high still. Not exactly 2,000rpms, but I would say around 1,200 to 1,400rpm. The two odd things is that I sometimes come back to a stop and put it into neutral and it is idling normally. The other weird thing is that the throttle seems very sensitive by just tapping it very slightly. I don't have anything to read any codes, but I don't have any kind of CEL. The only thing I could think is that I maybe messed up the throttle body servo..?
Old Nov 26, 2013 | 09:57 PM
Khan28's Avatar
2012 C300 Sport 4MATIC (current) 2006 C280 Elegance 4MATIC (sold)
Make sure you placed the airbox firmly down and the air filters inside it are properly seated in. That can definitely cause a high idle. It might be something more but try that first.
Old Nov 27, 2013 | 02:15 AM
Moviela's Avatar
https://mbworld.org/forums/c-class-w...-fix-free.html
Old Nov 27, 2013 | 03:33 AM
c240
I have triple checked that everything from the elbow up is firmly in place. Could it be some kind of rubber gasket/ o-ring?
Old Nov 27, 2013 | 03:38 AM
c240
I really wouldn't like to remove that damn throttle body.. :/ I didn't have this issue before the cleaning. The problem does seem to stop once the engine warms up. Are there any kind of temperature sensors around the area of the MAF and TB that could have messed up?
Old Nov 27, 2013 | 03:40 AM
c240
I would like to thank everyone for their help. This is my first Mercedes, and they seem to be pretty overly engineered.. Which is not what I am use to.. Coming from a 93 240sx
Old Nov 27, 2013 | 06:49 AM
junctionvip's Avatar
mercedes cl500
Check all the vacuum lines all the breathing hoses make sure they are nice an tight. The smallest leak can cause the most annoying fluctuation when u come to a stop. Also I forget what the sensor is called but there is one tht bolts to the intake manifold it has a screen on it if u pull it off the manifold u should see it. Its rigg by where the tb bolts up but sometimes they get gunk on them. I'm new with mercedes myself but I'm learning somewhat quickly.
Old Nov 27, 2013 | 12:59 PM
samaritrey's Avatar
Super Moderator
THE C350
So you cleaned the TB with it still on the car? I would finish the job and take it off of the car clean it fully and replace the gasket that goes between it and the Intake. As everyone has said also check for loose vacuum hoses and wires you may have damaged. This will also give you the opertunity to look at the TB better and if you want to clean out the motor side (some one posted pictures on here which would be helpful) I would also check the MAF and get some MAF cleaner if it is the original one/ very old. Also make sure the MAF is plugged in and that the air cleaner seal and the plastic tube seals are good. I changed mine a year or so ago and they were rock hard and fell apart into three or four pieces while a new one is like a rubber band. Then make sure that you don't have any air leaks bypassing the MAF or air cleaner.
As you said this car is over engineered but honestly not very different than any other car built in the last 10 years... your Nissan was just outdated and simple (I miss my older cars they were so simple .)
Old Nov 27, 2013 | 04:10 PM
Khan28's Avatar
I hear you about the Nissan bit. I had a 2000 Maxima before buying my C280 and it was darn easy to work on and had arguably the best V6 motor of all time in it. The thing is it felt like a tin can compared to the Benz which feels very solid. These MB cars aren't all that daunting although a delicate touch is required in some aspects when working on it. I'm wondering if you may have damaged your MAF since you said the issues go away when the car warms up. I know when the MAF sensors on the Maximas went bad people complained of a hesitation when the car was cold but the problems were non existent when it warmed up. What did you clean your MAF with?
Old Nov 27, 2013 | 04:55 PM
chazman's Avatar
2006 C230 & 2002 C230
He didn't..... according to his first post.
But I think he should have cleaned the MAF since it was already out and who knows if got contaminated while it was out.
1. Clean the MAF (take it out & clean).
2. Reclean the TB again. Possibly ISC (idle speed control) assy got clogged or contaminated.
3. Once all assembled, while engine is idling, spray carb cleaner around the air intake joints. If idle rises, you have an intake leak.
Below photo is from my C230 MAF cleaning.
Old Nov 28, 2013 | 01:41 AM
c240
I didn't clean out the MAF. I'm 18yrs old, and this car has broke me after a Trans flush..filter..gasket, Mobil 1 oil/filter change, power steering flush, and haven't even made it to the spark plugs yet. I'll definitely get some CRC MAF cleaner, and if my check is enough I'm going to replace all the rubbers under the hood, and get a TB gasket. I honestly need to take it off, the carbon build up is the worse I've ever seen. These engines have pretty bad blow back, and pulls way too much oil into the TB through the PCV.. Was thinking about making a oil catch can...?
Old Dec 1, 2013 | 07:39 PM
Khan28's Avatar
Yeah these cars do need to maintained a bit more often with more replacements compared to a Japanese car but do it little by little if it isn't urgent. This year I took care of the filters (engine and cabin), engine oil and filter, spark plugs, MAF and TB cleaning and fuel filter by myself and the dealership that I bought it from replaced the oil cooler due to a leak before I bought it. Next year I'll take it to a indy who will drain, flush, replace filter and refill the transmission for me (messy job) and I'll also have the front and rear differential oil replaced whiles it at the shop up on the hoist.
