W203 Replacement Mirror Glass Wiring?
I therefore bought replacement mirror glass from a well known auction site and attempted the change over myself with the help of a couple of YouTube videos....I did get the mirror on in the end, however the wiring for the heating element was different on the anti dazzle glass than on the new mirror glass. Therefore I doubt very much if I have attached the heating element connection in the correct way!
I have attached a photo of the anti dazzle mirror I have taken off; The two connectors are quite far apart on this mirror and one of the connectors looks to be built into the mirror; on my replacement there are two connectors that are close together...and only one connector comes from the actual door mirror itself!
I am quite sure that the heating element won't work with this different connector...has anyone come across this before? Thanks
But since I did remove the anti dazzle mirror from my car, I haven't noticed it get any darker/lighter since removing its power source...I am much happier with the standard glass...just the inbuilt connections from the car leave me with only one single wire connector and another connector which plugs into the auto dazzle mirror (I have attempted to show where it plugs into on the mirror); these are the only connections that are apparent.
When I removed the anti dazzle mirror I was only expecting to see it plug into two wire connections at the car side, not the one wire and the 4 pin plug which plugged into the mirror.
