Error Code P0102
Old Jan 26, 2014 | 11:37 AM
selwyng's Avatar
2001 w203 C180
Error Code P0102
Hi Guys
I desperately need some advice on this problem.
Last week while driving the car started sputtering/jerking. I pulled over and saw the CEL was on. The code was P0102 (MAF circuit low input).
I disconnected the MAF and started up the car- it was fine. The idle and acceleration was normal. So I drove home.
When I got home I connected the MAF the problem resurfaced and the CEL came on. The codes I got this time was P0102 as well as P0113, so I cleared the codes.
I disconnected the MAF and started up the car-(this is where I need the advice). The car idled fine but as soon as I pressed on the accelerator it spluttered and it couldn’t rev any further then 2000rpm . The car just splutters and switches off.
The CEL came on with the code P0102. Could it really be the MAF that needs replacement? Seeing as though with or without the MAF I cannot get any acceleration? I don’t want to spend close to $520 on a new MAF if that’s not the problem
Ever since then, the only code that comes up is P0102.
I drive a 2001 C180 with the M111 engine (non compressor).
Old Jan 26, 2014 | 06:55 PM
Glyn M Ruck's Avatar
Super Moderator
It looks as though that MAF is toast.
Also check your fuel pressure. When last did you replace the fuel filter?
Old Jan 27, 2014 | 02:16 PM
selwyng's Avatar
2001 w203 C180
Thanks Glyn. I replaced the MAF today.. now im getting error code P0113(intake air temperature circuit high input). Is there a separate sensor for this?
The original error code P0102 no longer shows up.
I replaced the fuel filter about 4 months ago.
2 weeks ago i sent the car for a service. I decided to check the oil level today and the oil is pass the max mark on the dipstick (way pass the max mark).
I know this is unhealthy for the car-but can this be the cause for the issues im experiencing?
Old Jan 27, 2014 | 03:40 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
Sometimes these cars would just refuse to start if there's too much oil. Even if isn't directly causing your issue, you should drain some oil. Too much could create unnecessary oil pressure.
Old Jan 27, 2014 | 03:52 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
If that's correct, there must be a sensor to tell the ECU about overfilling.
Which sensor monitors the oil overfill?
Old Jan 27, 2014 | 05:25 PM
Super Moderator
Correct the oil level.
Drive the car for a couple of 100Km's to let everything auto calibrate then cancel codes & see what comes back. The IAT sensor is built into the MAF.
High oil level has nothing to do with your issue.
Old Jan 28, 2014 | 02:55 PM
selwyng's Avatar
2001 w203 C180
Thanks for all the responses.
I forgot to mention that even after changing the MAF, the car is not driveable.
Error code p0113 keeps coming up. The car idles perfectly now but as soon as i press on the gas it splutters. This happens with or without the MAF connected.
I'm trying my best to diagnose the problem myself as some of these mechanics are charging exorbitant call out fees.
Old Jan 29, 2014 | 12:31 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Just a thought. Is the MAF the correct MB one for your car?
Old Jan 29, 2014 | 09:59 AM
bop11's Avatar
350 GLK, C280
Did you check the oil again? Are you making oil? coolant leak ? Did you check the coolant level and are sure the intake temp isn't too high? Might want to check the cables and connectors especially at the processor. Corrosion can cause abnormal reading.
Old Apr 10, 2020 | 12:07 PM
Minakeddis's Avatar
W203 200 kompressor 2000
Same problem
hallo,
I wanted to ask did what was the problem at the end?, as I am having the same issue now and changed the MAF but didnt help.
Old Jun 6, 2020 | 04:10 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
Sounds like an aftermarket maf sensor was installed. Or rarely, even a brand new oem maf can be bad, maybe dropped during shipping, etc
