Another fuel gauge problem
Old Feb 9, 2014 | 02:42 PM
okkie's Avatar
2005 c350
Question Another fuel gauge problem
Hi guys, I have read most of the fuel gauge threads. My problem is, that no matter what, it never indicates more than half full when I fill the tank. Is it the fuel sensor or must I replace the pump and the sensor? Your valuable input will be appreciated.
Old Feb 9, 2014 | 03:34 PM
samaritrey's Avatar
Super Moderator
THE C350
Your car should have two sensors one on each side and one includes the fuel pump. Sounds like one has gone bad so it indicates half instead of full. I know that most people seem to replace both sides when they do the job while others say you don't have to. I would check both sides and see if you can find an obvious issue.
Old Feb 10, 2014 | 02:26 AM
okkie's Avatar
2005 c350
Thanks Trey, is there any way the sensors can be checked with a multi-meter, or will this be a specialist job?
