Is it sludge???
UK & USA packaging claims.
Germany & sensitive country claim. (English version)
- To rule out head gasket blow. I checked coolant level and appearance. No coolant loose and looks okay.
- I tried to do longer trips to get engine hot. There is still sludge under oil cap but decreased. I am in Canada and in these days we are experiencing mines 20's. Temperature reaches around 85 degree on gauge which is normal I think.
- I changed oil and this time I put Castrol 0W40 instead of Mobile. Will see if it will be different.
Those were the update for now.
Hi gmphertford,
Thank you for your addition. I checked the oil and it seemed okay. No creamy sludge or indication of water. It was just dark color which is normal I think as it has been 10 k km.
So I did the same thing you did check the coolant (all looked good). So I also changed the oil. I used the Mobile 1 0W-40 Euro spec oil with a bosch fleece filter.
When I pulled the plug the oil poured out dark brown but no different then any other used oil I have seen. I pulled the filter out and once again nothing that look odd.
So as others have said the white milky stuff is normal and the only thing may be to change the oil at a shorter interval. Oil and filters are in a reasonable price range and the process is easy enough. So I will just change the oil more often.
Interesting to see whether it continues during warmer times.
Crankcase venting gear should be in perfect condition with no brittle old kinked hoses.
Carsy, I think cold weather has responsibility doing this. I will be watching it in the summer to see if it is persist.
