LED Bulbs
At the very least I'd want to replace my turn signals, and possibly brake lights. The only problem with the brake lights is that they're mounted pointing up, but LEDs don't transmit their light equally in all directions like normal bulbs, so i was thinking of making something out of aluminum foil or similar material to reflect the light in the correct direction.
Ok so which one do you buy then if you wanted to get them????
Or do they all fit....want to change my lights to the left low beam which one is it?
As for the other bulbs, such as turn signals, rear lights, and such, pay attention to the 1156 or 1157 designation, because they ARE different lights, with different sockets. Turn signals normally use the 1156, so buy accordingly.
Whether you want the narrow or wide beam version, how many LEDs on it, etc. is up to you.
Love the look...less than thrilled with the longevity....considering that's supposed to be one of the LEDs advantages.
Ive still got my turns LED's.
Try Formymercedes.com
