Brake Lights stay ON when driving
C-Class W203 2004
Hi,
My C220 CDI today started giving me an error on the dashboard saying "Brake lights, visit workshop" ... i noticed that the brake lights will never go off even when i am not pressing the brake pedal.
I checked for a sensor under the brake pedal but there is none... i hade the ECU reparied few days ago...removed the ECU and it didnt affect the lights so its not a connected issue...
STAR displays the REAR SAM with -F- and when i read the error codes it says something like terminal 54 short circuit in the positive or something like this... what can it be??
C-Class W203 2004
Today in the morning the problem just went away by itself. I guess the front SAM got wet when i worked on the ECU.
I found a very helpful thread actually that can help others as well. This issue is probably caused by water in the front SAM.
https://mbworld.org/forums/c-class-w...-workshop.html
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Yes ~ a wet SAM will do it. I always forget that the brake lights work via a fuse in the front SAM & the rest of the tail lamp cluster operates via the rear SAM.
