w209 cluster in w203
Old 11-17-2003, 11:24 AM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
Whats Happening With the W209 Cluster?
How are you guys doing with the swap out of the W209 to the W203 coupe.
Any updates or news as this was a current topic b4 the forums went down.
Regards
Neil
Old 11-17-2003, 03:51 PM
oggle's Avatar
E320
I wanna know as well. Steve?
Old 11-17-2003, 04:07 PM
Harris's Avatar
The CLK55 cluster costs almost USD1000. I do not have the guts to buy it and TRY to put it on my 32 without knowing that it will work for sure since the cluster is not refundable. So, I am still holding my breath and wait for one of you guys to try it first.
Old 11-17-2003, 06:38 PM
Sincity's Avatar
Harris,
Sell me those 20" Brabus Mono IVs for my ML for $1k and you will have your cluster....
Old 11-17-2003, 07:47 PM
Former Vendor of MBWorld
MBenzNL's Avatar
some slow@$$diesels
NOT!!! before I am home again...where I have the car AND cluster plus stardiagnose to fool around with!
The coupe, btw, has a complete different cluster design as far as the housing goes...
greetingz,
Old 11-17-2003, 07:58 PM
tom incredibie's Avatar
'03 c320wz
hurry steve hurry! i wonder if the new c55 cluster will look similar to the clk55's cluster hrmms..
Old 12-01-2003, 04:00 AM
rsyed's Avatar
C200 CDI w203
now that steve is back home, he is probably going to give it a shot... Thought i open this thread to remind Steve that there are a number of anxious people waiting for the outcome
greetings from vienna
rumman
Old 12-01-2003, 05:54 AM
MBenzNL's Avatar
some slow@$$diesels
hahaha - that was (still is) on today's programm...you are too early!
greetingz,
Old 12-01-2003, 11:07 AM
Kar don's Avatar
Mercedes-Benz
greetingz,
mmmm cant wait to hear the results!
Old 12-01-2003, 12:30 PM
MBenzNL's Avatar
some slow@$$diesels
Seemed to be working fine except for the fuel gauge that kept running up and down...I am not sure whether that was a problem in the instrument cluster itself or is something that can be reprogrammed with stardiagnose (similar to 208 ICs in 210s or 210 ICs in 208 or 202s).
The W209 IC is slightly bigger then the W203 IC though and doesn't fit in the dash without any modifications...
greetingz,
Old 12-01-2003, 01:21 PM
Kar don's Avatar
Mercedes-Benz
greetingz,
could you make it fit? What do you think you would have to do?
Old 12-01-2003, 01:32 PM
Guest0001
Guest
Posts: n/a
I guess thats not good.
Old 12-01-2003, 02:43 PM
Harris's Avatar
Thats not very good news. I guess we all have to wait and see whether the C55 has the 209 look-a-like cluster!
Old 12-01-2003, 05:08 PM
MBenzNL's Avatar
some slow@$$diesels
Shave the dash...which doesn't sound to well...
The backplate with the locks is bigger on the 209 cluster...if it would have been the front that was bigger - it would have been swapeable...
I need to find a non functioning 203 cluster to see whether I can use that housing in combination with the 209 electronics and faceplates...
greetingz,
Old 05-06-2004, 07:55 PM
NickySTHLM's Avatar
C200K
greetingz,
i just got a used CLK cluster from ebay and of course the first thing to do was to test that everything works fine.... i took out the original cluster, connected the cable to the new one and started the car... everything seemed to work at first.... then i noticed the "problems" - so far only 3:
1. the fuel tank indicator was not stable - it was moving up and down from full to empty and back... i'm guessing that's some self calibration procedure and that i gotta fill the tank full the when i connect the cluster for the first time...?
2. the total mileage display (the little one under the main display - the one that also shows the current gear and gearbox programme) first shows 7640 km and then clears and just shows 6 dashes - so when parked the display shows "P ------ S" - i'm guessing that the new dash has to be programmed at the dealer to my car?
3. the phone page is gone - i have factory mounted phone kit in the car and when i change pages on the steering whell the page "telephoone" is not there... i'm guessing again that the dash has to be reprogrammed at the dealer to "know" which equipment my car has?
now when it comes to fittment... the outer size of both clusters seems to be abou the same... the back though is bigger on the 209... but i theink there is a pretty simple solution to the problem. behind the cluster there is like a glove for the cluster - a plastic piece that is as big as the cluster and where the cluster fits... i'm pretty sure that if you buy that glove as a spare from 209 and mount it into the 203 it will work just great...
Old 05-23-2004, 07:12 PM
carlssonist's Avatar
2002 mercedes c320
Instrument Cluster Swap? 2005+ or w209?
Can we swap the old instrument cluster with the new 05 ?
aerG500 (09-06-2017)
Old 05-23-2004, 08:35 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Re: 05 instrument cluster
Nope. The new protocol is MOST whereas the old is DB2.
Old 05-23-2004, 11:45 PM
2002 mercedes c320
Re: Re: 05 instrument cluster
too bad...what about the 3 spoke steering wheel ?
Old 05-24-2004, 05:56 AM
miroj's Avatar
Why not just install the MOST gateway ? I dont know much about the signal connection but I was interested to hear it can be driven by D2B or MOST.
Old 05-24-2004, 10:40 AM
SUNILP's Avatar
2015 E250D
The instrument panel is not connected via fiber optics so d2b and most have nothing to do with it. The problem is we don't know if the CANBUS signals have been changed in any way. We'll have to wait till Steve gets one soon.
Old 05-24-2004, 11:13 AM
miroj's Avatar
Poor Steve ..... does he have to do all the work ?
All you need is a pinout of the back connector. I for one cant see the merit in changing the data link, having said that - the new APS COMAND warrants addtional functions.
Bottom line is W203 designation still includes AMG55 in the EPC .... so I am assured it is not a radical new car. If the door controllers are in the same list as the old ones then its not going to be any different in the cluster.
I dont see MOST as a huge problem myself. Its a better system and I am sure other people will jump in and make new devices for most since motorola has a habit of making it good for developers.
Old 06-04-2004, 05:27 PM
MBenzNL's Avatar
some slow@$$diesels
...neither do I see that (the need to change data links) nevertheless MB changed a lot on the W220 when they upgraded it a bit and went from comand 2.5 to comand 16/9 (both D2B based and both CD rom) meaning that the 16/9 in an older W220 won't be compatible with the MF steering wheel...who knows what MB did to the W203???
I have a IC on order though...will have to see what happens when installing it in an older 203...
greetingz,
Old 06-04-2004, 06:22 PM
breastroker's Avatar
2003 C230 K , 2001 ML320
Steve,
I want the 2005 Coupe instrument panel
Old 06-04-2004, 11:58 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
for a sedan if you could it wouldnt be too bad because it should fit the dash, but in a coupe i'd have to buy a new dash and that could get pricey.
Old 06-05-2004, 12:25 AM
The 2005 Coupe has the same new "4 gage instrument panel with vertical multifunction display", with chrome rings, as the sedan.
Not sure if the Coupe has the different outer indentations like the 2002-04 Coupes. The photos aren't clear enough.
Quick Reply: w209 cluster in w203
