SQUEALING NOISE
Old Apr 27, 2014 | 01:57 PM
ChuckinTucson's Avatar
2012 S63, 2013 E350 Bluetec
SQUEALING NOISE
My sister-in-law has a '05 C230K. She has a habit of shutting off the A/C when she parks the car overnight. in the morning she starts the car. Everything normal. She turns on the A/C everything normal. She shift to reverse to back out of the driveway and there is a squealing noise coming from the engine compartment. She shifts to drive, no more noise. Only happens in reverse on warm mornings with the A/C on. I'm thinking compressor pulley. Any other thoughts.
Old Apr 27, 2014 | 05:54 PM
Jhartmann3's Avatar
2001 C240, 2011 Honda pilot EX-L RES, 2005 Tundra
Before replacing AC pulley, make sure serpentine belts are good and belt tensioner is good. AC compressors aren't cheap, just had to replace mine.
Old Apr 28, 2014 | 05:41 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
No-no-no, that's definitely the alternator overrun pulley
I had the same exact issue with the noise etc. Scared the crap out of me.
The problem is, with the extra load on the engine the idle is somewhat unstable.
However the alternator is large and inertial, it tends to keep spinning at whatever high speed the engine fluctuated to. With the overrun pulley seized, this makes the serpentine belt skip and slide, hence the noise.
If she doesn't get it fixed, the AC pulley will break and she will have to replace the AC compressor.
Car probably has about 100-120k miles?
Old Apr 28, 2014 | 05:54 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The C230K cars are all very rough in reverse.. I'm inclined to agree here with VVF, if the alternator pulley bearing goes out it is adios, sayonara A/C compressor. The compressor is also a swash plate design, always spinning so get it into the shop ASAP.
Old Apr 29, 2014 | 03:27 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Please explain to an old bloke why the air-conditioner will be damaged if alternator overrun pulley fails ? Thank you.
Old Apr 30, 2014 | 02:06 PM
greenv's Avatar
2003 C230 Kompressor
If the alternator overrun pulley fail a big vibration was observed in the pulley. Due to this vibration the air-conditioner compressor clutch gone.
Old Apr 30, 2014 | 02:17 PM
VVF's Avatar
VVF
Solid pulley == seized alternator pulley
