2005 C230 misfire, unsighly scene after removing coil (pics)
Old Apr 30, 2014 | 01:48 AM
notjoe's Avatar
CLK soon
I seem to have a major problem with my 2005 C230 with approx 140k km
The CEL came on yesterday after about 20min driving and the car started losing a lot of power, so I pulled over to make some phone calls, turned it on after about half hr and it started and ran fine so didn't think much more of it. Same thing happened today on the way home from work, this time let it sit for 10min or so, started and barely made it home witrh very little power it had. Hooked up the OBD code reader right away which showed P0301 (Cyl 1 misfire)
So naturally I proceeded to remove the coils to inspect the ignition system and was confronted with this unsightly scene:
Cyl #1
Cyl #2 coil
Cyl #2
Both Cyl 1 and Cyl 2 seemed to have a major leak of coolant (or water?) and oil into the spark plug wells. Also once I removed the plugs I noticed inside the cylinders full of fluid
Is this a sure sign of head gasket failure or something else might be at play? I am baffled since I have not experienced any low coolant warnings or white smoke. I wanted to check the oil dipstick for signs of coolant in the oil but then realized these cars don't come with a dipstick
Is there anything else I can check to make sure? Any input will be greatly appreciated
Old Apr 30, 2014 | 03:22 AM
MacVidMB-V8's Avatar
W209, W124
You should have kept liquid from going down into cylinders.
If you don't have a mightyvac then stuffing paper towels into plug area would have eventually worked.
In any case, don't put plugs back in and crank, could be very bad. (Liquids do NOT compress...so, immovable object against unstoppable force = ????)
Crank with plugs out and hope the liquid ejects.
I had an Alfa years back that would eventually flood the plugs like that. It was valve cover gasket, no big deal but had to remove oil.
The misfire could easily have been sparks shorting to ground.
Old Apr 30, 2014 | 04:32 AM
notjoe's Avatar
CLK soon
^^ thanks I cleaned everything up with contact cleaner and put it back together, removed the liquid from inside the cylinder by inserting a windex sprayer and pumping, worked ok but didn't get everything out. Either way just took it for a test drive and it all seems fine (for now)
Might have been just the spark plug shorting, I switched plug with #2 and coil with #3 so if the code returns I'll be able to pinpoint the issue
Thanks again, I was getting worried there since finances aren't the best now and head gasket would be big $$, thankfully seems I got lucky
Old May 1, 2014 | 04:10 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Assuming it's setup like the M111, which it probably is, there are these orings in the valve cover that compress over the holes where the plugs live. This has happened to folks with M111 engines, they pulled the valve cover and replaced the orings.
For me, I've never this problem, and perhaps that's because when I started to notice some leaks around the outside of the valves cover I tightened it.
So moral of the story is, check your valve cover, see if any of the bolts are loose.
Gently tighten them, check it frequently, and if necessary replace those farking O-rings.
Old May 1, 2014 | 04:23 PM
Well curiosity got the best of me, here's a pic.
It's not exactly an oring, but here it is...
A2710160121- about $10 us each and there are 4 of them.
I used the VIN of a 2005 C230 off of ebay.
Attached Thumbnails 2005 C230 misfire, unsighly scene after removing coil (pics)-m271-valve-cover.jpg
Old May 8, 2014 | 04:01 PM
Gee I hate it when I go waaay out of my way for ungrateful newbies who never bother to read, acknowledge, or provide thanks to the responses to their posts. Why do I bother?
Old May 8, 2014 | 06:53 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Yep... not pretty.
And that's part of the reason why not many people answer newbies' posts.
Old May 9, 2014 | 10:20 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Thank you for posting this helpful, complete reply. Feel better now?
Actually, I just had my vc replaced. Which at 175k, shouldn't be much of a surprise.
I'm surprised the OP hadn't lost sufficient oil to get the malfunction to come up.
Old Apr 6, 2015 | 02:15 PM
rortiz8's Avatar
2005 mercedes c230
Finding part help
Where can I find number 35 on the picture by C230 sport Coup down in the comments?
Old Apr 6, 2015 | 05:22 PM
chazzz's Avatar
'05 MBZ C230K and '09 MBZ C350
Get the part number you see in the picture and bring it to the nearest dealer, they should have it in stock. Or you can order online.
