Turn signal out and not fixed with new bulb!
Former Vendor of MBWorld
Yesturday i got 1 malfunction saying my left front turn signal is out, indeed it was. So i bought new bulbs today, put one in and it still did not work. It came with 2 so i said i will try the other maybe both did not work. Well the 2nd one did not work either. So i took the right one out and put it in the left and it still did not work. I out a new bulb in the right and it worked fine, so the new bulb is working, but the left still does not go. An i suppose to do anything else after i change a bulb to like reset anything? maybe to make it work again? or is that not possible? would the malfunction go away right after it sees its working? or is there a trick to this? i really hope i am forgetting to do something, i dont want to make a trip the dealer, its very out of my way.
C 240
There is actually a wiring harness problem to the front turn signals.
If you take the socket out you will likely see that the connections are burnt. I guess you can either scrap the stuff off or the dealer can repalace it.
yea i kept having that problem... my left turn signal goes out every once in a while..and also by right... so basically both....i think the connections arnt touching right... so when i went for my service at the dealer i told them to replace it ... works fine for now
2001 C320
they replaced yours? dangit all they did to mine was run a ground wire to it..i made a big fuse about that problem..it happened to me more than 5 times. good luck
2001 C320
i wanted them to replace my whole light because it was a consistant problem.i mean the car was still under warranty.they insisted on the ground wire..grrrr ..just to save money!..but as of late,it hasnt been doing that..****!! i hope i didnt jinx myself
W203 220 CDI T-Model
Best, go to your dealer. He can replace the socket. If don't do it for free, help yourselve:
Solution, based on the contact conditions: Clean the contact of the socket with sandpaper and bend it a little bit. If there's a hole in the contact, make a soldering point to close it.
I did this and I never had this problem again.
Dirk
2001 C240 6spd
I had the same problem with my turn signals. The right one went out when I first got the car - they replaced the wiring harness. The MB service told me that they have had problems with this and that there should be a tech bulletin out on this. They were supposed to replace both turn signal harnesses, but evidently they did not. My left one just went out right before Thanksgiving. Took it to the MB dealer near my sister's house and they fixed it - all under warranty.
c230 Coupe
If you go to the dealer make sure you put the mercedes bulbs back in, my dealer was being a pain about using replacement bulbs that werent mercedes, said he could void the warranty on the signals because the owner is not supposed to replace them. what a crock, huh?
2001 C240 6spd
The front turn signal sockets on my car were replaced under warranty. Dealer said he had a bulletin on this problem.
The new parts were: 203-826-02-82 socket; 000-545-78-80 gasket.
Engineering change....
This problem is covered by an engineering change that involves adding wiring and bypassing faulty contacts. Don't know the EC number.
Ok, it looks like i will have to take a trip to the dealer, i just hope i dont need to keep it there overnight, thats the part i hate.
Oh, btw, i will put the stock bulbs back in.
