check engine light turned on after putting gas,then lost power,need help pls!!
Old May 16, 2014 | 07:25 PM
carmichael15's Avatar
2001 c320
Unhappy check engine light turned on after putting gas,then lost power,need help pls!!
check engine light turned on after putting gas,then lost power,every time i rev up engine shuts down,take my keys out put it in again starts,rev up dies again!! can someone please help me??
Old May 16, 2014 | 07:48 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Get the code read.
Old May 16, 2014 | 08:25 PM
blzdout's Avatar
C240 4MATIC
Originally Posted by N_Jay
Get the code read.
+1
It sounds like a fuel delivery issue. Something may be clogged in your fuel line or your fuel pump is dying. It can also be MAF related if it's out of wack.
But we'll know better if you get the code read first.
Old May 17, 2014 | 06:44 AM
Glyn M Ruck's Avatar
Super Moderator
Check for misfire codes. 300, 301, 306 etc.
Make sure plug wires & coilpacks are healthy if you find random misfires.
Check CPS
Check fuel pressure at the Schrader valve on the front fuel rail. s/b 3.8bar or 55psi while cranking. If not check for clogged filter or lazy fuel pump.
Good luck.
Old May 17, 2014 | 03:06 PM
2001 c320
thanks guys!! im getting the code read this monday.
Old May 18, 2014 | 07:49 PM
2001 c320
replace sparkplugs and filter,check engine light turned off,drove the car for 30 minutes,condition was good,parked the car in front of my house rev the engine check engine light turns on,engine dies!!! whats wrong with the car???
Old May 18, 2014 | 07:51 PM
blzdout's Avatar
C240 4MATIC
What codes did you get for your check engine light?
Old May 18, 2014 | 08:15 PM
2001 c320
Old May 18, 2014 | 08:17 PM
blzdout's Avatar
C240 4MATIC
Well once you get the code read, you can post it here & we can help you diagnose the problem. It's more than likely a sensor or something.
Old May 18, 2014 | 08:18 PM
2001 c320
thanks a lot!! keep you posted.
Old May 19, 2014 | 02:45 PM
2001 c320
codes are,P0300,P0302,P0304,P0335.
Old May 19, 2014 | 03:52 PM
blzdout's Avatar
C240 4MATIC
Cylinder 2 & 4 needs either new spark plugs, spark plug wires or coil packs. Might even be fuel injectors but I doubt it.
You also need a new crankshaft position sensor.
My mother's ML does the same thing as your car (hesitant to start). It's more frequent at gas stations. The CPS needs to be replaced ASAP.
Old May 19, 2014 | 03:58 PM
blzdout's Avatar
C240 4MATIC
also, if you just replaced all your spark plugs, check if cylinder 2 & 4 spark plugs are tight enough.
Old May 19, 2014 | 04:26 PM
2001 c320
ill try to replace the crankshaft position sensor tomorrow,keep you posted,thanks again!
Old May 19, 2014 | 04:27 PM
blzdout's Avatar
C240 4MATIC
Glad I could help.
Old May 22, 2014 | 10:35 PM
2001 c320
replace crankshaft position sensor,fixed!!! thanks again!!
Old May 23, 2014 | 01:58 AM
Super Moderator
Pleased it's sorted.
Old May 24, 2014 | 06:31 PM
2001 c320
will the check engine light turn on when you dont have freon in the compressor?
Old May 24, 2014 | 07:06 PM
2001 c320
missing part!!
can someone tell me what is the function of this part? and what is it called? im missing mine!!
Attached Thumbnails check engine light turned on after putting gas,then lost power,need help pls!!-pic2.jpg
Old May 25, 2014 | 09:20 AM
blzdout's Avatar
C240 4MATIC
No, the check engine light would not come on. Is yours still coming on? You've mentioned you had P0302 & P0304.
That thing in your engine bay is just for drainage I believe. Nothing serious.
Old May 27, 2014 | 02:30 PM
2001 c320
my son was driving the car,he said he stopped at a red light and turned on the a/c then the check engine light turned on and the car died,he started the car it started then he turned off the a/c,check engine light turned off, put some r134a in the a/c, car runs normal now.
Old Jun 6, 2014 | 09:26 PM
2001 c320
car wont start!! code p0335!! again!! found out the mechanic installed a crankshaft position sensor replacement part not an oem part!! engine is turning over but wont start, is it the same part???? help!!!
