Window Switch/button Broke Off.....
Old 05-29-2014, 07:30 PM
bigspender101's Avatar
2003 c230k
So my drivers side front window switch/button broke off when I went to roll up the window. I guess I pulled up to hard on it. Pics Below....Can I just snap in a new button or do I need to replace the whole assembly? Luckily I was able to kinda set it in there so I could roll it up. It looks like the tab is completely broken off.
Old 05-29-2014, 10:59 PM
VVF
VVF's Avatar
2005 C230K(sold), Mk7 Jetta
I'd try to carefully pry out the lower-left switch and swap it with the upper-left one...
They appear to be the same (?)
You have nothing to lose after all
My switch is also cracked (but left side) and on its way.
Old 05-29-2014, 11:04 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Unfortunately, sounds like you already know the answer to the question you've posed. Definitely buy it online; dealers completely hose you on the prices of those switch assemblies.
Old 05-30-2014, 12:58 AM
2003 c230k
So I was able to superglue the piece that broke off and It snapped back in but I know its not gonna last. I'm not going to get the whole assembly if I don't have to. I guess a trip to the local pick and pull is next. I think I may try that VVF good Idea!
Old 07-03-2014, 03:57 PM
wvadam's Avatar
C230 COUPE 2003 M271
I got a good price at ecs tuning. I would check there as well. Good luck.
Old 07-03-2014, 04:30 PM
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
wvadam,
Thanks for the shout-out!
bigspender101,
We do indeed have the window switch panel for your car. If you are interested, you can get to it on our website by clicking HERE, or by clicking on the photo below.
If there is anything else I can help you out with, please feel free to post or send a PM!
Old 07-05-2014, 08:30 PM
Poppy1's Avatar
2002 C320
I have this same problem well as the passenger window button is about to go. Glad to know that ECS has it covered. Is this an actual MB part?
Old 07-07-2014, 07:50 AM
ECSTuning's Avatar
2012 SLS AMG
Poppy1,
Yes, the window switch assembly posted above is a genuine Mercedes-Benz part.
Old 07-07-2014, 08:12 AM
Poppy1's Avatar
2002 C320
Thanks ECS.
Old 07-08-2014, 12:05 PM
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
I found the chinese version for $38 a pop....
http://www.ebay.com/itm/Power-Master-Window-Switch-Console-for-Mercedes-W203-C-Class-C320-A203821067-/281270800372?pt=Motors_Car_Truck_Parts_Accessories&hash=item417d0bcff4&vxp=mtr
Any one used this.....
My pass side switch keeps popping out of the socket If I try to use the one click function...need to replace mine as well..
any input on the above....performance, quality and the lights on these chinese ones...
javvy
Old 07-08-2014, 01:07 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
I need the coupe version.
Old 07-08-2014, 03:45 PM
VVF
VVF's Avatar
Good find Javvy!
$40 looks much better than $120
A friend of mine bought a Chinese switch row for his 2002 Passat.
Apparently the quality of plastic is on par with the OEM. I felt little burrs on the buttons (probably left from the molding process), but he said it's similar to how the original ones felt.
Old 07-09-2014, 07:49 AM
ECSTuning's Avatar
2012 SLS AMG
C230 Sport Coup,
We have the coupe version of the switch group available on our site as well. This replacement switch assembly is a genuine Mercedes-Benz part, so you can be sure that it will fit and function just like the original.
If you are interested, you can get to it on our site by clicking HERE, or by clicking on the photo of the switch below.
If there is anything else I can help out with, please feel free to post or send a PM!
Old 07-09-2014, 10:31 AM
Javvy's Avatar
Purchased the Chinese switch for 38.99 free shipping from LA....will post updates when I install and have it in my hands.
Javvy
Old 07-12-2014, 09:46 PM
krazzdav's Avatar
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
Lightbulb
a good place to get parts is also from http://www.mymercedesparts.com or http://www.genuinemercedesparts.com
$105 for drivers side or $35 for passengers side from mymercedesparts here
a little more from genuinemercedes parts here
so may just need to weigh the shipping costs from everyone
It's best to put the actual part# from EPC into the website so that you know you get the right part
Old 07-15-2014, 06:23 AM
Javvy's Avatar
OK got the switch, Quality looks good....Do any one have a DIY link or video that I can follow to remove the old switch froim the door....juts dont want to experiment and brake some tabs etc.....any resource would be helpfull...hope I dont have to remove the complete door panel...
javvy
Old 07-15-2014, 08:09 AM
Poppy1's Avatar
2002 C320
Here is a video about taking the door panel off. After that it should be pretty easy.
Old 07-15-2014, 09:45 AM
tommy's Avatar
Yes, you do have to remove the panel. The switch is held on by the white tabs you can see on the sides of the switches pictured. To remove, slide them up (you can see the slots they go into pretty easily on the reverse of the door panel); to install, do the opposite, and don't forget to reattach the wiring to the new switches. You should be able to do all of this without having to mess with the door rod, which you don't want to have to remove; it's a bit tricky.
Old 07-15-2014, 10:32 AM
neurodave's Avatar
2001 C320 w/ Sprt Pkg
I think my drivers side is starting to go as well. It feels a bit flimsy, so I try to keep from putting too much pressure on it.
Old 07-15-2014, 11:55 AM
VVF
VVF's Avatar
Javvy, could you post some pics of the switch? Thanks!
Old 07-15-2014, 11:59 AM
Javvy's Avatar
Paitence my young paduvan.......lolol
Will do a side by side onces I have the oem one out....lolol
Javvy
Old 07-15-2014, 04:58 PM
VVF
VVF's Avatar
Ha, seems like somebody tries to make money on those switches: http://www.ebay.com/itm/01-07-MERCEDES-BENZ-C230-C240-C280-C320-MASTER-POWER-WINDOW-SWITCH-TESTED-/151351932165?_trksid=p2054897.l5661Also, the passenger window cut-off switch seems reversed (switch to the right to enable windows vs left for OEM) which is nothing
Old 07-21-2014, 09:00 AM
Javvy's Avatar
This update is especially for VVF, here you go side by side comparison.
The chinese master control door switch fit and finish is similar to OEM. The only difference is the image on the child lock button and the illumination light of the switch is slightly brighter than OEM. I like it though as it just states that it is the master control for all windows. Works perfect and has a longer harness. I would recommend it highly to all that want to replace theirs and save some $$$. Shipping was super-fast and am completely satisfied with my buy. If I have any reliability issues I will definitely report back to this thread. Some side by side comparison pictures attached.
Enjoy...
Javvy
Attached Thumbnails Window Switch/button Broke Off.....-20140719_142002.jpeg   Window Switch/button Broke Off.....-20140719_142036.jpeg   Window Switch/button Broke Off.....-20140719_142047.jpeg   Window Switch/button Broke Off.....-20140719_142055.jpeg   Window Switch/button Broke Off.....-20140719_142114.jpeg
Window Switch/button Broke Off.....-20140719_142133.jpeg
Old 07-21-2014, 09:01 AM
Javvy's Avatar
More Pics...
Attached Thumbnails Window Switch/button Broke Off.....-20140719_142156.jpeg
Old 07-21-2014, 12:15 PM
Thanks anyway but it's only 70 bucks with free shipping from Mercedes
Originally Posted by ECSTuning
C230 Sport Coup,
Quick Reply: Window Switch/button Broke Off.....
