Command Install HELP: Speed Pulse
Old Dec 8, 2003 | 04:54 PM
c class 279's Avatar
M
Hey guys,
Just got my Command in from Steve, I'm just about to install. I have two questions, though: where do I put the GPS antenna, and where do I tap the speedpulse wire???? Thanks!
Old Dec 8, 2003 | 07:37 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Re: Command Install HELP: Speed Pulse
Originally posted by c class 279
Hey guys,
Link
Old Dec 8, 2003 | 08:36 PM
Lynn's Avatar
The GPS antenna is stuck to the underside of the dash between the center vents and the instrument cluster.
Old Dec 8, 2003 | 08:40 PM
M
Lynn,
Thanks, that's 1/2 of the problem. I'm having big trouble with the speed pulse, though. I really have no idea how to remove that whole fuse box assembly to get to that pin. Maybe a dealership trip. I hope Steve can get me some better instructions...... Also, I wish someone had some pics or something of how to do it. Not fun.
Old Dec 8, 2003 | 08:51 PM
Lynn's Avatar
I can't help you with the speed pulse. Steve installed my COMAND so I didn't have to learn about that.
Old Dec 8, 2003 | 09:13 PM
M
I emailed Steve earlier, haven't heart back. I hope he's not gone from net access again, because I want to be able to get this thing done.....
Old Dec 9, 2003 | 12:31 AM
ravens1488's Avatar
i have pics here of MY installs of the 463 Units in 203 modells...
Chris
Old Dec 9, 2003 | 07:55 AM
M
Chris,
Is there anyway I could view your pics? I would really appreciate it. My email address is ebwing@aol.com, if you would be so kind. Thanks!
Old Dec 9, 2003 | 03:50 PM
ravens1488's Avatar
pix r out!
Chris
Old Dec 9, 2003 | 05:05 PM
M
Christ,
I really appreciate the pics. Where do I route the wire, though? And also, how do I remove the fuse tray? Just take the four screws out?
Old Dec 9, 2003 | 06:30 PM
M
Wow, I have no idea how to take out the third screw, I need special tools or something. Ugh. Any ideas, Chris?
Old Dec 9, 2003 | 06:48 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Hey guys,
The Info is on SEVERAL sites! Do a search
If You are Not Sure on The Install I Would have a person that
Knows Mercedes do it or help you ...To avoid any Problems!
This site will help you re Info!
http://www.startekinfo.com/StarTek/
Steve can Install it for you IF you will wait. Its Very easy IF
YOU know what you are doing! or work on Mercedes and can
read a Wiring schematic 45 min to a Hour.
Old Dec 10, 2003 | 12:26 AM
M
Alright, got the fuse box out, just have to route the wire. Any ideas...?
Old Dec 10, 2003 | 05:22 AM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
C Class 279
Can I ask you a question has it been really difficult to fit?
I'm considering a self fit or driving to Holland to get mine fitted.
Ihav fitted a CD Changer that wasn't pre-wired and be curious of your feedback.
Regards
Neil
Old Dec 10, 2003 | 08:03 AM
M
I would say if you can have Steve do it, go ahead. Plus, then you get to use your nav to find yourway through/back from Holland.
Old Jun 17, 2004 | 08:01 PM
Tariq's Avatar
S500 W223 2021
c class 279
Did you install the command???
How its going on???
hope that solved..
Old Jun 17, 2004 | 09:09 PM
tom incredibie's Avatar
'03 c320wz
speed pulse? what is this speed pulse you speak of? i installed my comand with the help of my cousin never remember anything about a speed pulse?
Old Jun 17, 2004 | 11:21 PM
Tariq's Avatar
S500 W223 2021
Do you rememeber the steps of installing???
Thats might help some users who are planning to install command without steve.
Actully I am planning to get Command soon from Steve but Steve unable to come to my country for instalation only one command that why i need some help...
Regards
