problem with cables after replace bose amp
Old Jul 5, 2014 | 06:21 PM
Kadri88's Avatar
C270 avantgarde
hi there, im new, im a guy from italy with a C270 avantgarde
After one year with problem on the radio, yesterday i tried to replace my audio10 with bose implants, with a kenwood radio and a sony xm1000 4channel amp (do you know if bose implant have filters on the speakers?).
I connected the radio in the A plug, without the C plug .
The radio lights up.
The problem is in the new amp, i connected the positive and gnd from the bose pin, and a imput control carried from the radio with the rca, but corrent doesn't pass in the cables from the bose pin...
i have 4 cables i don't know where to connect, they are number 1 2 3 and 8 in the pin
here some photos of the cables
the blue cabel is only one, i bent only to put inside
here's the kenwood iso, connected only +, gnd and illumin
rose cable outside plug is the remote control
here i tried to connect the blue cable of the radio (+) to the "probably" + of the C pin but i think it doesn't help
here my HK ca260
many thanks
ps: if i connect the amp directly from the battery it works, but tweeter sounds all frequency without any cut
Old Jul 6, 2014 | 05:04 AM
gogos's Avatar
Clk 200k cabrio w209, Jeep Crand Cherokee 3.0 CRD, Smart For two
You can check the pinout connectors here: http://www.benzworld.org/forums/audi...omand-2-a.html
The best you can do is to run a new fused wire from the buttery via the passenger side to the trunk in order to power up your amp. There is a 40amp fuse at the rear sam but if your amp is too powerfull, forget it.
The bose speakers are 2ohm with no filters and they are crup. You must replace them. Also if the amp output is high, check if the thikness of the oem speaker cables are suitable.
I would recoment to ask a pro installer if you are not sure what you are doing. Good luck.
PS: Make also a search in the forum, many members have done that and they have post detailed write up.
Old Jul 6, 2014 | 06:06 AM
Kadri88's Avatar
C270 avantgarde
thanks a lot gogos, i think it's better if i connect a new wire directly from the battery.
but here in this topic https://mbworld.org/forums/c-class-w...tallation.html
i see here that the power source cable was taken from the fuse...do you know where must i connect the power source?
