2005 c230 k sedan tranny
2002 c230 kompressor coupe, 2005 c230 kompressor
My transmission seems to pause in between shifts like it's slipping and my car only has 80000 miles can anyone shed some light on this situation? Thank you in advance
I keep reading that a fluid and filter change can do wonders for these transmissions. Might also want to check the connector for the trans control unit to make sure no fluid has flown up there. It's located under the passengers side footwell. Good luck!
