Fuel vapor emissions leak CEL help!
Last edited by Wayne's Benz; Jul 19, 2014 at 09:10 PM. Reason: Add more to question
If you are battling to fill then the carbon cannister might be saturated & you likely have a blocked breather.
You access behind the fender shroud & under rear seat.
Remove 4 plastic covered bolts in front of the rear lower seat squab. Remove the lower seat.
Access to fuel senders, pump etc. is below 2 round metal covers.
