When u turn car on, how long until windows roll down?
Old Aug 6, 2014 | 11:54 PM
scottonfire's Avatar
2013 c250
I know this seems strange, but after turning on the car my windows won't respond to roll down for about 5 seconds which, when it's 100 degrees, is 4 seconds too long. Is this normal? No other electrical issues, and when I turn the key to just before starting it the windows will roll down right away.
Old Aug 7, 2014 | 02:25 AM
kanadian's Avatar
c240 2002
that sounds like a personal problem.. mine are instantaneous
Old Aug 7, 2014 | 10:59 AM
neurodave's Avatar
2001 C320 w/ Sprt Pkg
Quite the helpful answer.
Anyway, I don't exactly get the question. Do you mean that when you get in your buttons don't respond for the windows or the auto windows don't work?
Old Aug 7, 2014 | 11:18 AM
2013 c250
The button windows won't respond for 5-6 seconds after starting. It's weird. But if the car's off and the key's in, the windows will roll down no problem.
Old Aug 7, 2014 | 12:30 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Mine respond instantly after starting.
Could it be battery related? Like the blower fan and radio cuts out for a sec when you are cranking if the voltage is lower than [12.3v I guess]...
Old Aug 7, 2014 | 01:27 PM
2013 c250
One other weird thing, I think. When I take the keys OUT of the ignition, and the doors are still closed, I can turn on the radio. Is that normal? It's cool, but not sure if some weird electrical permutation.
Old Aug 7, 2014 | 03:06 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Yes, the radio working is normal.
Old Aug 8, 2014 | 06:22 AM
Mooda's Avatar
W204 09 C300 4MATIC
why not roll down the windows before you get in from outside the car? point key at the drivers handle and hold the unlock button.
dut the delay is not normal mine react as soon as i hit the button even after start.
Old Aug 8, 2014 | 02:50 PM
VVF's Avatar
VVF
Mine for instance stopped working about a year ago. Too lazy to fix, as it it relatively a PITA. I don't mind opening the windows from inside the car.
Old Aug 8, 2014 | 04:12 PM
2013 c250
Doesn't work either
