Audio10 Mute Button
Rating: Thread Rating: 4 votes, 5.00 average.
Old Dec 20, 2003 | 03:31 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Question Audio10 Mute Button
Just installed Audio10 today.
Do I need to take my car to dealer to program TEL PRESENT in order for mute button to work?
What is TA VOL in the menu for? Goes from 0-3.
Will post pics later today.
Old Dec 20, 2003 | 03:58 PM
Lynn's Avatar
TA is for Traffic Advisory. It is not used in the United States.
Old Dec 20, 2003 | 04:46 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
There is no mute button on the Audio 10 unit. If the integrated phone is installed, an incoming call would mute it automatically.
Old Dec 21, 2003 | 12:10 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
cuz when i press "mute" button, it says "no TP"
so i thought by setting TEL PRESENT, this button will work...
i guess that cannot be done w/o phone kit... :-(
Old Dec 21, 2003 | 12:33 AM
vadim's Avatar
This is not the "mute" button. There isn't one in the Audio 10. Even if the integrated phone were present, you wouldn't be able to mute the sound by pressing a button - mute gets activated automatically when a call comes in.
Old Dec 21, 2003 | 12:53 AM
tiffc888's Avatar
Yea, the button you are thinking about is not mute.. it's some funky european traffic button that, like Lynn said, is not used in the US. Basically that button doesn't do anything in the US.
Old Dec 21, 2003 | 02:18 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
icon surely looked like mute button.
thx for clearing it up guys.
Old Dec 21, 2003 | 06:01 PM
pixelpro's Avatar
c230k
it works on a few stations for me
On my audio ten, there are a few stations that when i tune into in RDS mode that illuminate the TP signal in the upper right portion of the display. When TP is illuminated if I hit the mute button it does just that, it mutes all audio. This only happens on about 5 stations in Detroit. Hope that helps.
Old Jan 1, 2004 | 03:19 PM
apl175's Avatar
That button will mute the audio for R-D-S and EON (Extended Other Networks) enabled areas and stations.
I believe that when a Traffic Advisory is broadcast, the system will umute automatically so that you can listen to the traffic broadcast.
There's also a way that you can set it up so that the system interrupts playback of CDs to broadcast in a similar way.
Old Jan 1, 2004 | 04:38 PM
vadim's Avatar
This button is used to mute the current audio playback *only* if a traffic programming transmitter is present. If this is the case, then pressing on this button will switch the receiver to playing the current traffic update. Otherwise, this button will have no effect whatsoever. In the U.S. RDS is in its infancy, and propably will stay in this state forever, so this button is useless here.
Read more in the Audio 10 manual:
http://www.c-coupe.info/Audio10ManualPart3.pdf
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
