Transmission Swap?
Old Aug 18, 2014 | 03:44 PM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Transmission Swap?
Is it possible to put a 6 speed manual into my '02 C320 wagon? I think some coupes came with manuals during that time. Would it mate up w/o any issues? What about the electronics...I assume some ecu's would have to be reprogrammed. Would this be viable? I've seen some trannys on ebay for around $700. Any thoughts?
Old Aug 20, 2014 | 03:08 PM
hanknum's Avatar
Anyone? Bueller?? Bueller??
Old Aug 20, 2014 | 10:45 PM
Glyn M Ruck's Avatar
Super Moderator
Yes it's possible but not financially viable. By the time you have fitted a flywheel & clutch to the engine, Fitted a new pedal set, hydraulics & MT, plus got the electronics, inhibitor switches etc. sorted the cost will be prohibitive. Your diff ratio might also be wrong. Don't know what you have fitted.
Old Aug 21, 2014 | 03:32 PM
hanknum's Avatar
Thanks Glyn...that was the info I was looking for.
I guess if/when I get rid of the C320 wagon, I'll look into either a B5 or B6 Audi S4 Avant. Though, I did find that Subaru did make a Legacy Wagon one year (2005) with a detuned STi motor...can also be had with a manual.
Old Aug 21, 2014 | 06:02 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Most wouldnt do it as it'll probably be expensive and hard to get the electronics to work out. There is a forum member on here under the name jk8trjosh (or something like that) who has done 6 speed swaps on m113 5.0s on the r170 platform. Its doable, but a tad bit expensive. I believe he literally opens up the ECU and solders stuff... scary, but hes got a few successful examples and is lining up to do a 6spd on an m113k.
Old Aug 22, 2014 | 03:37 PM
hanknum's Avatar
Thanks John. I think it'd be cool to have a 6speed wagon, but not very cost effective.
I still haven't made it back up there for work...I'll let you know when I do.
