Problem with my c220 w203 2004 Diesel CDI
Old Aug 20, 2014 | 03:31 PM
K3rt#'s Avatar
c220 cdi w203
I got problem with my c220,
when i hit the pedal car does this :
engine is like shutting force down or something.
Old Aug 20, 2014 | 05:54 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Does it do that when you are driving too?
Gasoline engines do not rev above 4k RPM when in park, maybe this is also some sort of engine over-rev protection?
Old Aug 20, 2014 | 11:48 PM
K3rt#'s Avatar
c220 cdi w203
It is Diesel and on the road same thing appears when hitting pedal.
Old Aug 21, 2014 | 01:00 AM
Glyn M Ruck's Avatar
Super Moderator
It might be fuel starvation. Check filters & LP feed pump.
Diesels run exess air & accelerate by being given more fuel.
Check for stored codes with an OBDII scanner.
Old Aug 21, 2014 | 02:25 AM
K3rt#'s Avatar
c220 cdi w203
Oil, Air, Fuel filter changed. OBDII shovs II. cylinder error . injectors is changed 1k back and EGR is working fine .
And electricity is coming to the injector .
Old Aug 21, 2014 | 12:03 PM
Super Moderator
Then get someone to check the fuel pressure from the LP feed pump in the tank.
Old Aug 21, 2014 | 03:01 PM
K3rt#'s Avatar
c220 cdi w203
fine, if the engine gets more air the white smoke appears, but i get black smoke, the problem is somwhere in the air system, OBDII shows no fault code .
Old Aug 21, 2014 | 05:22 PM
Super Moderator
Do you get a puff of black smoke that clears or constant black smoke?
Old Aug 22, 2014 | 10:44 AM
K3rt#'s Avatar
c220 cdi w203
when i hit pedal revs are stuck and black smoke comes ,car have no power and makes the same sound like in the video,when i hold pedal and in 10-15 secs revs normalaises and car accelerates. but when i hit pedal slowly nothing happens no smoke or smthing only when i hit it instantly to the end, but i havent tried it with kickdown , more smoke and more revs trouble. puff of black smoke after revs are normal again.
Old Aug 22, 2014 | 01:51 PM
Super Moderator
Check that fuel pressure.
You might have a problem with the turbo or turbo controller. You might also have a problem with the throttle position sensor or TB actuator.
Under normal conditions if you punch the throttle you should see a puff of smoke & then it should clear as the turbo spools up.
Old Aug 22, 2014 | 03:38 PM
K3rt#'s Avatar
c220 cdi w203
well i clear the aircontroller and check turbo. interesting is that, 0 errors, but i see turbo charching speeds and other specs so i must get the orginal specs to control turbo work but i googled turbo specs and no result i cant find the airflow speed and other parameters about that turbo.
Old Aug 23, 2014 | 01:19 PM
K3rt#'s Avatar
c220 cdi w203
i puted my symptoms in the autodata and autodata shows this throttle sensor is broken but i can hit pedal and revs go up, so i broke the sensor and 1 capacitor was black other white, so i need the sensor diagram and capacitor colors to get trought that question.
Old Aug 23, 2014 | 05:32 PM
Super Moderator
Buy a new sensor. None of Benz diagrams show those values. For the TPS hall sensor replacement you have to buy a whole new pedal assembly.
