C240 Throttle Body bad???
Old Sep 17, 2014 | 10:47 AM
MVPMedia's Avatar
W203 C240
Engine will only rev high if I very slowly press gas. If I give it a normal acceleration press (like from a stoplight) then it will sputter out quickly. I've tried disconnecting the MAF to see if there are any changes, but no. There was one time I started the car to troubleshoot it and the car had no response at all from the gas pedal.
The TPS code popping up is P0220 or P0221, I think. Something to do with TPS circuit B. I've tried replacing the gas pedal sensor with a new dealer part but that didn't help. I guess the only other cause I can find from searching this forum is a bad throttle body.
If I take a chance and buy a used throttle body from ebay, can I program it myself with the ECU throttle reset key protocol? or is this something I have to take to the dealer?
Old Sep 24, 2014 | 04:07 PM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
I've got a good TB off of my '02 C320 if you are interested...PM if you are.
Old Sep 25, 2014 | 02:09 AM
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
You don't absolutely have to reset the TB if u replace it. It will work if u don't but does need an SDS to synch it properly.
